Thread: Low Ph and TA
    JenMichelle's Avatar
    Apr 2014
    St. Louis
    65
    Low Ph and TA
    Hey guys, I just have a couple of quick questions. My results are:
    Cl 4
    CC 0.5
    TA 50
    Ph 6.8
    Cya 50
    I have not closed my pool because I want to wait for the temp to drop, but I do have it covered with a solid cover due to the leaves dropping.
    Questions:
    1.Is that TA level ok?
    My ph won't stay above 7.2, I will add borax and it will rise to around 7.2, but no further. It drops after about 10 days or so back to the 6.8 ish. I'm only adding liquid chlorine and a tab here and there. Should I just keep adding borax until I close or do I need to be adding something else.
    2. Is it ok that my pool is covered while the pump runs here and there?
    I just pull back a section where I can test water.
    Thanks guys!
    24' x 52" AG / Hayward Sand Filter
    Hayward Power-Flo 2 Speed Pump
    TF100 test kit / Pool Rover Hybrid Robot
    St. Louis, MO *GO CARDINALS*
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Low Ph and TA
    1. I would bump TA up to 70-90. PH may like it better there. Use baking soda. Then raise PH with the borax. See how the PH does there. The tabs will lower PH also. You want to increase levels in small steps and see how the things are. May PH is rock steady with a TA of 80, but that is my pool. Yours will be different.
    2. Yes. I'm doing this right now till I pull the pump and filter. 😎
    Jeff
    Apr 2014
    St. Louis
    65
    Re: Low Ph and TA
    Got it. Thanks so much. Do you add pillows now or do you do that when you drain?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Low Ph and TA
    I don't use pillows and I only drain down below my skimmer opening then I cover it with the aquador. It's like a Tupperware lid for the skimmer opening. My winter cover rests on top of the water or ice.
    http://www.poolandspa.com/catalog/pr...Pool-Cover.cfm 😎
    Jeff
    30,403
    Re: Low Ph and TA
    About the only reason for your pH to drop is the use of tabs....more than you are indicating.
    Use of Borax will raise pH and TA both.
    Use Pool Math to calculate your dosages and stop using tabs.
