Thread: Motor not running, hot to the touch?
    Aleforge's Avatar
    May 2014
    Wentzville, MO
    149
    I went outside this morning to check on the pool (getting ready to close it) and noticed no water was coming out of the returns. I went over to my pump and noticed it wasn't running, I could smell a burning smell and I could feel heat form the pump 6 inches away. (wasn't going to touch the housing). The filter basket was filled, water level up half way on skimmer and didn't notice anything that could of caused the pump to run dry. The breaker wasn't flipped either.
    Did my pump shoot craps the week of closing?
    Thanks!
    In ground (installed 2000), fiberglass, cartridge filter, Pentair Super Flo Single speed pump (2014).
    Oct 2013
    Chapin, SC
    1,141
    Re: Motor not running, hot to the touch?
    First thing to do is check if the shaft turns freely-- you may need to use a screwdriver to find that out. If it does, then the next test is the capacitor. There's a utube video on how to do that using an analog multimeter. If that's good, you may need to replace the motor as a minimum. Make sure before you do any of the aforementioned, you remove power at the circuit breaker.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Aleforge's Avatar
    May 2014
    Wentzville, MO
    149
    I was sick all weekend and did not get a chance to go out and try this, although the pump looks very old, most likely original. It would be about 11 years. This is the worst possible time for it to go out as I am tight at the moment on money. I wish there was a way to close the pool minus a pump and worry about it next spring.
    Anyways, I will check it out however do you think it might just be a better idea to buy a new one if the motor is shot?
    Thanks!
    Oct 2013
    Chapin, SC
    1,141
    I recently replaced mine, but that was mostly because the seal plate was cracked, adding another $100 to the repair. I had just replaced the start capacitor 6 mos before.
    30,432
    Repairing an 11-yo old pump might be penny-wise and pound foolish.....you just never know. A new 2-speed pump may pay for itself in a year or so.
    Aleforge's Avatar
    May 2014
    Wentzville, MO
    149
    Obviously I need to find out the model and type of pump I have. It has to be some off brand as there is no name on it. However will it be possible to to match something up so I don't have to redo the plumbing? I am hoping to just wire it up and connect it. Where do you guys normally find the best prices on pumps if you don't mind me asking?
    Thanks!
