Thread: polaris always stuck
    my vacuum is always stuck against the wall. every time i look at it, its stuck. If i move it it will go straight to the wall then get stuck. stay there for its allotted time until it automatically senses its stuck and pull away then straight into the wall again..what gives....why is this thing always stuck and not able to move around the pool swifty?
    26k gallons IG painted Plaster
    Hayward Swimclear Cartridge filter model ST1152 1.5V 1A
    A. O. Smith Pump 2.2HP 3450RPM (runs 5hrs/day)
    Vacuum model BY06-09 3/4HP 3450RPM (runs 2hrs/day)
    Manteca, Ca.
    May 2013
    Fort Lauderdale, FL
    423
    Re: polaris always stuck
    Have you measured the RPM of the wheels? Adjusted the float? Moved the jet that squirts out the back?
    It doesn't "sense" that it's stuck- the reverse module is on a timer.
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
