Thread: Test Kits
    Sep 2014
    Oro Valley, Az.
    3
    Test Kits
    Which test kit is the right one for salt water pools? I have the K2006.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Test Kits
    That is it. You may want to buy the K-1766 salt kit also.
    Welcome to TFP!
    Hopefully you stick around so it would help us if you would add the following information to your signature
    • The size of your pool in gallons
    • If your pool is an AG (above ground) or IG (in ground)
    • If it's IG, tell us if it's vinyl, plaster/pebble, or fiberglass
    • The type of filter you have (sand, DE, cartridge) and, if you know, the brand and model of the filter.
    • If you know, please tell us the brand and model of the pump, and mention if is it a two speed or variable speed pump.
    • Date of pool build/install, particularly important if less then a year old.
    • What kind/model of water test kit you are using
    • Other significant accessories or options, such as a spa , SWG, or cleaner
    Support the site
    Sep 2014
    Oro Valley, Az.
    3
    Re: Test Kits
    Thanks, I do have the K1766 as well. Just wanted to make sure the K2006 was the right kit for the rest of the testing.
    Sep 2014
    Oro Valley, Az.
    3
    Re: Test Kits
    Pool is 13,000 gals.
    IG/pebble
    Hayward sand filter
    Hayward pump single speed
    Pool built in 2006 ?
    Using Taylor K2006/Taylor 1766
    2 week old Pintar IC60 SWG
