Results 1 to 7 of 7
Thread: Right switch to wire a two speed pump
    Mar 2012
    Cooper City, FL
    24
    Hello,
    I am replacing my 1HP MaxFlo pump motor with a two speed motor (STS1072RV1) and I need help to choose the correct switch to switch between low and high speed. I already have an intermatic T104m timer to turn it on and off. I know I can get a t106m timer to select the 2 speeds, but since I am not going to run it daily on both speeds, it is a waste of money to get a t106m. I was wanted to get a cheaper switch to change speeds.
    10080 gallons 28x12 rectangular pool. 1HP Hayward Maxiflo pump. 75 sqft Hayward Cartridge Filter. SWG Hayward Aquarite. iRobot Verro 300 Pool Cleaner. Plaster color Pewter.
    38,301
    Re: Right switch to wire a two speed pump
    A 3 way house light switch is cheap and easy to install in a water tight receptacle.
    Mar 2012
    Cooper City, FL
    24
    Jason, how many AMPs should be the switch rated?
    38,301
    How many amps is the motor rated for? Most of the 230V motors are under 15 amps which a standard light switch should be fine with.
    Mar 2012
    Cooper City, FL
    24
    It is 5.4 AMPs on high and 2.2 on low. 15A is enough, right?
    38,301
    Yes, 15 amps > 5.4 amps
    Mar 2012
    Cooper City, FL
    24
    thanks
