It's somewhat normal to see a large burn off like that still after sunrise. I'd expect you'll see a larger one once all your CYA is dissolved. The pump is running 24 hours still correct?
Tonights numbers.FC = 14CC = .5TA = 150PH = 7.4CYA = just added today, will check in the morningYou are assuming that I started at 15 ppm. I was not tracking my levels exactly I was just making sure I had chlorine in the pool.
