Results 1 to 10 of 10
Thread: General Question about SLAMMING
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,248
    Luckily in my first year I have not had to go through the SLAM process. Pool is closed. I enjoy the forum and most questions and the learning process is answered by reading posts occasionally. But I do know that next year I will have to help friends with this problem.
    So my question is as follows:
    Why does the PH about to be adjusted between 7.2 and 7.5 while SLAMing? I fully understand the reliability tests at higher chlorine levels, etc. I doubt most people would go swimming if they had a green pool unless it was cleared up. Once cleared then the PH can be adjusted accordingly. Does the PH rise while SLAMing? Can the PH just be left alone if it was between 7.4 and 7.8, or could some damage be caused to a Vinyl Liner or plumbing during the process?
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: General Question about SLAMMING
    You can assume that during the SLAM pH is going to rise some. Heck, just the added areation of brushing and running the pump 24/7 is going to cause rise.
    Bringing it down to 7.2 before you start gives you head room for rise during the SLAM.
    Support the site
    Catanzaro's Avatar
    Jul 2014
    2,248
    I guess maybe I am asking if the PH has to be adjusted or this can be done after the SLAM process? Then again, the TA will drop and you will be in the same position to increase TA, etc. Best thing to do is never get to a SLAM unless it just happens.
    30,403
    I'm not sure I understand. Is there a specific reason you do NOT want to adjust pH beforehand or are you just curious as to why?
    The "why" is simply because you are working towards having your pool water within suggested guidelines and pH is the first parameter to adjust. I can't think of a a scenario in which you would not want pH within guidelines first.
    Catanzaro's Avatar
    Jul 2014
    2,248
    Curious to know why? That is all.
    As I mentioned before my pool is closed and I have had great success with the TF-100 kit and luckily I found this forum in my first season before I ran into problems. And believe me if I listened to the Pool Store my CYA level next year would have been 100 + and probably full of metals.
    Wanted to know if I help a friend clear up a pool next year if the PH can be lowered (assuming it is high) at the end of the SLAM process. But I will follow the instructions accordingly if I have to help a friend.
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by tim5055 View Post
    I think this pretty much explains it. It's exactly how I would have replied if I saw the question first.
    Catanzaro's Avatar
    Jul 2014
    2,248
    Thank you everyone
    Sep 2013
    Connecticut
    728
    Take a look at this thread, if you haven't come across it before:
    http://www.troublefreepool.com/threa...efore-shocking
    Thread was started in 2010, but there are some updated posts from 2014 also; interesting comments from chem geek and other knowledgeable posters.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,766
    ^in other words, lowering ph to 7.2 makes the slam work better because chlorine is more effective at lower ph
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Mar 2007
    San Rafael, CA USA
    12,082
    Well, the reason I gave for lowering the pH first wasn't so much for chlorine effectiveness though that is a factor, but rather that the pH when adding a lot of chlorine goes up a lot and can risk metal staining or cloud the water with calcium carbonate which then has one think the pool isn't getting cleared of algae when it really just needs the pH lowered (say, by letting the chlorine level drop back down).
