Results 1 to 7 of 7
Thread: Pool company plumber says I don't need airlock on main drain?
    I am having some repairs done on a return line, so the pool company plumber went ahead and did the closing for me today. I noticed that he blew out the main drain line at the shutoff valve junction near the pump. He then added antifreeze to the line, re-attached the shutoff valve and called it good. I questioned him about the lack of an air lock and he said that was not necessary due to the depth of the main drain line. This seems odd to me since all previous closings have used the airlock approach - any input on this?
    IG 14K gunite - built mid-1980s; sand filter 125 GPM;2.2 HP pump; TF100 test kit
    Kansas City
    May 2013
    Long Island NY
    419
    Re: Pool company plumber says I don't need airlock on main drain?
    He is right, as long as the water is below frost line it won't freeze. But it's easy to do and that's why I do it. I like to blow out what I can, add a little antifreeze and create an airlock to keep the water from pushing back up the pipes. I sleep better.
    If its below the frost line and he put some antifreeze in it, your fine.
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    thank you - now I can sleep tonight!
    Kansas City
    Ellington, CT
    262
    Quote Originally Posted by samt View Post
    I like to blow out what I can, add a little antifreeze and create an airlock to keep the water from pushing back up the pipes. .
    How do you add the antifreeze an maintain an airlock?
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, AquaVac TigerShark cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
    May 2013
    Long Island NY
    419
    I put antifreeze in the skimmer pipes only.
    Ellington, CT
    262
    Ah...ok, I though you were talking about the main drain.
    May 2013
    Long Island NY
    419
    Quote Originally Posted by laprjns View Post
    Yes that was my fault sorry, But I have done that before, add antifreeze to main drain with airlock. It's pretty simple if you blow out through the pump with a compressor. Blow the skimmers as usual and plug those. Then turn the skimmer valve to OFF. Now your main drain is open , open up the clean out basket at the pump and pour in the antifreeze. I only use a gal.
    Turn compressor back on and it will push the majority of water out before the antifreeze gets there. Then turn the valve to off on the drain side and create an airlock.
    I don't do this anymore because I put my cover on month before I blow the lines and I can't see the main when it starts to spit the orange antifreeze.
