Results 1 to 11 of 11
Thread: chlorine level question
    How high can you raise your chlorine level on a vinyl lined pool without damaging the liner?
    16x48 (6000 gal )Intex Ultra 1/2 HP Sandpro sand filter Hydro Tools skimmer
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: chlorine level question
    It generally depends on how high your stabilizer level is. Why do you ask?
    Support the site
    I have already accidentally bleached out my liner getting rid of mustard algae and I do not want to make the same mistake in the future.
    May 2014
    Franklin, NC
    9,184
    Wow, you must have nuked the pool for a long time. We do not "shock" our pools, we follow the SLAM Process when there is a problem and that includes a higher level of chlorine for only 24 hours to get rid of the mustard.
    I see you have your pool information in your signature, but we also ask for your location in your profile as location can affect answers to questions.
    Support the site
    Shirker's Avatar
    Jul 2014
    Athens, GA - USA
    132
    I have not had any battles with algae yet (Knock on wood!). You need a good test kit and keep track of your chlorine levels (both free and combined) as well as your stabilizer (CYA), PH, and alkalinity (TA). With this information you can calculate your target chlorine level. Stay in this range and hopefully you will not have algae problems to begin with. I find that managing PH first makes hitting all of the other target levels easier.
    TF-100 | 13.6k gal (24' Round) AG | Chlorine | Sand Filter | Two Speed Motor | Installed June 2014 | Last Opened April 24 2016
    I did follow the slam process but I had a high cya at the time.
    I was hoping someone would know what the highest ppm is that I could go to without damaging my liner in the future.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    How high you can go without damaging your liner depends on your CYA level. What is your current CYA?
    Isolated Spa - 345 Gallons
    At the time my cya was over 100 so I brought it up to 40 ppm. I have since dropped it down to 30 but I am asking theoretically in case I need to slam in the future.
    Shirker's Avatar
    Jul 2014
    Athens, GA - USA
    132
    It depends on your CYA level. I would try to keep the FC in range of this chart:
    http://www.troublefreepool.com/conte...art-slam-shock
    But you are just throwing darts if you don't know your pool chemistry. I'm sure someone much more knowledgeable will come along and answer your question if you post a full set of test results.
    38,305
    I am not sure how to say it any differently than has already been said ....
    The safe FC level is a function of your CYA level.
    At shock level according to the FC/CYA Chart, there should be almost no risk of fading your liner due to the chlorine.
    Now if you keep your pH too low, that could also fade the liner. There was also a thread where we suspect the liner was defective and it faded for apparently no good reason.
    Follow the chemistry recommendations you find here and your liner should be fine.
