Thread: Non-chlroine shock...use it or toss it?
    Jun 2014
    Boston, MA
    58
    While trying to finish up cleaning the pool for closure I went through the chemicals that came with the pool. We have a box of "winterizer" chemicals. It includes non-chlorine shock and algecide. Is it worth using this, or just doing the bleach shock before closing?
    24'x 54" Round Sharkline Oceanic installed summer 2014,Hayward EC45 bump style 1.5hp DE filter (using cellulose),TF-100 test kit. First time Pool owner- thinking about SWG
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Non-chlroine shock...use it or toss it?
    If you can list the active ingredients on the algaecide or the brand name, product name that would be helpful. Most likely you don't need either if closing when the pool temp is solidly below 60. The non-chlorine shock has it's uses but is not needed for winterizing.
    Isolated Spa - 345 Gallons
    Shirker's Avatar
    Jul 2014
    Athens, GA - USA
    132
    What is non-chlorine shock? I just went to Leslie's site but I don't see a list of ingredients there.
    TF-100 | 13.6k gal (24' Round) AG | Chlorine | Sand Filter | Two Speed Motor | Installed June 2014 | Last Opened April 24 2016
    Feb 2014
    Central Minnesota
    5,080
    Usually, non-chlorine shock is monopersulfate or MPS.
