Results 1 to 7 of 7
Thread: Fountain basin repair with epoxy resin?
    Hi all, I haven't been here in awhile. It's good to see the site is still going strong!
    I tried the google, with no luck, so I came to the experts for this problem. I hope you can help.
    I have a small patio fountain with a stained glass inlay bottom. It has sprung some leaks under the bottom
    What can I put on the top surface that can be submersed in water to stop the leaks that is clear? TIA
    AGP, POPUP, 3800GAL. SWG 2000 GPH pump. Over the wall skimmer. SE TX. NEWBIE
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Re: Fountain basin repair with epoxy resin?
    Are you planning on covering the entire glass area or just around the perimeter?
    My first thought is silicone caulk which will dry clear.
    Epoxy resin is usually not UV safe and will yellow over time.
    Support the site
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Yep, silicone!
    Hi thanks for the reply. I knew this was the right place to ask!
    Yes, the intire surface, I can't tell where it is leaking from the top.
    I Have found them on the bottom and will seal it also, tho it need not be clear.
    I guess I'll try the GE Silicone II. Is that the kind you mean? Everything else
    day's it can't be left below the water line or submerged below.
    Mike_W's Avatar
    Aug 2011
    Orange County, California
    142
    I ran across this while I was wandering the aisles of the big box store over the weekend. It is not clear however.
    Mike
    http://greatstuff.dow.com/products/pond-and-stone/
    ~17' x 34' IG pool with attached spa - 20500 gallons - Gunite with a "pebblesheen"-ish finish
    Jandy iAqualink with iPad and Jandy PDA remote - Pentair IntelliFlo VS 11018 Pump
    AquaRite SWCG - Pentair SMBW 4060 DE Filter - Really Old Raypak heater
    "Wall-E" an Arneson-Hayward Navigator - A couple of Jandy/Zodiac WaterColors LED Lights - Blue-White F-1000 Flow meter
    Quote Originally Posted by Mike_W View Post
    Mike
    That's nice to know they make that in dark color, now they don't need to paint it.
    Won't work for this app. but I like it. Thanks.
    Jul 2014
    Bastrop, Louisiana
    199
    Silicone would be a good choice because it is removable if it doesn't work/look right.
    A thin coat of fiberglass resin might be another alternative, but the downside is if its too thick it will have a yellowing effect.
    Randy H.
    Intex 18' X 48"
    G.A.M.E. Sandpro 75 Sand Filter (Single Speed 3/4 HP, 75 lbs sand, 2650 GPH, 7-way valve)
