Thread: How long for a Pentair 460737 MasterTemp 400K BTU Propane Heater to heat pool?
    Sep 2014
    Spicewood
    3
    I have a rather large free form pool, 130 per. ft. with deep end and spa. I estimate it to be in the 40,000 gal. range. It has a water fall on it as well. The water circulates through the spa when not on and over a spillway that drops 4' into the pools deep end.
    How long will it take to heat the complete pool?
    TIA
    38,275
    Re: How long for a Pentair 460737 MasterTemp 400K BTU Propane Heater to heat pool?
    Welcome to TFP!!!
    Well, we would need to know the starting and target temperatures to even try to estimate it.
    40k gallons is 332k pounds of water. You will get a little over 320k BTUs per hour from your heater. So, neglecting all losses (this is a HUGE assumption given all the aeration/evaporation happening from your waterfall), you would get about 1 degree per hour. So, with the losses, expect to get less than that. A cover would help retain a lot of heat.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Plus loss to ambient air temperature and amount of sun received will have an effect. A large pool with no thermal cover will loose temperature quickly.
    You say you are from "Spicewood" but a state would help pin down your temperatures.
    It would help us if you would add the following information to your signature
    • The size of your pool in gallons
    • If your pool is an AG (above ground) or IG (in ground)
    • If it's IG, tell us if it's vinyl, plaster/pebble, or fiberglass
    • The type of filter you have (sand, DE, cartridge) and, if you know, the brand and model of the filter.
    • If you know, please tell us the brand and model of the pump, and mention if is it a two speed or variable speed pump.
    • Date of pool build/install, particularly important if less then a year old.
    • What kind/model of water test kit you are using
    • Other significant accessories or options, such as a spa , SWG, or cleaner
      Welcome!!
    Support the site
    I have a MasterTemp 400HD with a 19,000 gallon vinyl inground pool. I typically get 2 degrees per hour.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    1-2 degrees per hour is correct. Of course there can be outside factors that could lower this value as well. When heating a pool it is best practice to keep it covered when not in use.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
