Results 1 to 8 of 8
Thread: Why Use a Pillow?
    Shirker's Avatar
    Jul 2014
    Athens, GA - USA
    132
    Why Use a Pillow?
    What exactly is the purpose of the pillow? Is it to keep the cover out of the water? Or is it to allow expansion for ice? Can I use one of the kid's big floats as a pillow? Do I even need to worry about one at all?
    Thanks in advance!
    TF-100 | 13.6k gal (24' Round) AG | Chlorine | Sand Filter | Two Speed Motor | Installed June 2014 | Last Opened April 24 2016
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,389
    Re: Why Use a Pillow?
    It does both. Allows for ice expansion and to decrease ponding of water and debris in the middle of the cover. As long as hard freezes are not an issue you could probably do without. If you drain below the returns and want to decrease ponding on the cover the cover pillow would work better since it would have more height than a standard pool float. You could also use a cover pump to drain the water that accumulates on the cover. You just have to be careful there are no holes in the cover so you don't drain the pool!
    Love TFP? Become a
    TFP Supporter!
    May 2014
    Strong Island NY
    16
    From personal expierence ... think of your pool as a giant Tupper Wear container that has plastic wrap over the top of it. Now poor a cup of water on top. Where does it settle? By keeping the center elevated you force the water to the outter edges of the pool along with any leaves and junk that may also fall on top of the cover.
    Long Island NY. 27' AG round. 17,000 gal. HAYWARD pump and sand filter
    Jun 2014
    Killingworth, CT
    21
    I rarely have pillows survive the whole winter without popping by spring. Does anyone sell quality ones built to survive a tough winter with snow & ice?
    I have a 30' round pool and after owning it about 7 years I still don't know exactly what I should be putting under the cover for the winter.
    30' Round, Hayward S180 Sand Filter w/ 1.5hp single speed Hayward pump
    Jul 2014
    Hope Mills, NC
    567
    Car innertubes will last.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    JoeSelf's Avatar
    Jun 2014
    Glassboro NJ
    333
    I use two round circle floats tied together.
    13700 gal, 32'x16'x54" AG oval, vinyl, Echo Canyon II, 8500 series, Narrow Yard, Safety Fence & Stair, Sta-Rite Crystal Flow T-210WF, 44 GPM, Hayward SP1580TL 1HP Pump, Aqua Luminator, Festiva wedding cake steps, March 2006, TFT-100, Speed-Stir, Sample Sizer. Avatar Credit: TJ Townsend
    Jun 2014
    Killingworth, CT
    21
    What's a round circle float?
    I'm also thinking car inner tubes now as well. Also large tractor tire inner tubes could really kick butt. Maybe Tractor Supply sells them?
    JoeSelf's Avatar
    Jun 2014
    Glassboro NJ
    333
    TUBE FLOAT.png I have this one and a larger one from intex that has really thick vinyl. Lasted maybe 5 swimming seasons. Big one on bottom smaller one on top & I tie them together in four places. The big one has openings where a string used to be.
    I use truck inner tubes two years after the second I had to get rid of them. One got a hole and the other was deteriorating.
