Results 1 to 7 of 7
Thread: Water line tile grout?
    Elgrecus's Avatar
    Feb 2013
    Los Angeles, CA
    57
    Hello TFP members, I am an architect designing a new single-family residence with a pool in Los Angeles and would like to know what grout people are using for the water line tile. We have had mosaic tile come loose in the past on some projects and are looking for the best water line tile grout on the market. Our office has specified C-Cure "MP Non-Sanded 923" in the past which seemed to work. Is there a product any experts would recommend? Maybe a Laticrete grout? Anyone used C-Cure in the past? Lastly, is it better to used mosaic tile with a mesh backer or does it not matter? Any thoughts are appreciated. Thanks in advance for your help.
    Pool Size: 9,000 gallons
    Pool Type: In ground, plaster
    Filter: Pentair 4000 Series D.E. Filter
    Pump: 1 HP Pentair Whisperflo WFE-4
    Heater: Sta-Rite Max-E-Therm 200
    Salt System: ECO-matic ESC 36
    Pool Cover: CoverStar, motorized cover
    Elgrecus's Avatar
    Feb 2013
    Los Angeles, CA
    57
    Re: Water line tile grout?
    Doing some more research in the office I found a spec from a pool consultant... this seems like a pretty good spec. The construction budget for the house is about $8 million (about $125k) for the pool, so money is not a problem. We just want the most bulletproof spec money can buy. Thanks.
    30,403
    Any latex-modified tile grout will perform fine. An epoxy based grout is even better but much more difficult to install and, therefore, fewer tradesmen that can do a nice job with it.
    By far, the biggest reason for waterline tiles coming off is improper installation and prolonged, severe weather. There is no type of grout that can save a shoddy workmanship or exposure to weather conditions over time.
    Just out of curiosity is the grout or thinset more important to prevent tiles coming off? I was under the impression it was the thinset.
    18' x 36' saltwater inground vinyl pool
    Jan 2014
    SE Louisiana
    147
    Some group (I can't remember the name) puts out a standard and paper faced is preferred glass tile type. Standard requires 95% or better contact of tile to thinset. Good info here ...
    http://www.glasstile.com/pdf/install...lation2012.pdf
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    If the tiles are coming off, the thinset was applied improperly or was the wrong type. Grout doesn't do anything except look nice!
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    I had to repair my waterline mosaic tile that came loose. I used a product called E-Z Patch 22 from http://e-zpatch.com/index.html. I used it to both stick the tiles back onto the wall and as the grout between the tiles. The replaced tiles stick better than the original, "professional" job and the product looks lots better than the original grout (no spalling, efflorescence, etc).
    I'm not a professional, though. If money is no object and someone will take the time necessary, I think it would be a nice-looking, effective solution.
    Good luck!
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
