Thread: Huge chlorine appetite
    Jun 2014
    Rogers, AR
    428
    We have owned our home since July 30 and I feel really comfortable with my pool. The liner was replaced two weeks before closing so the water is fairly fresh. I have found that any acid, baking soda etc. I add less than the calculator recommends since smaller amounts of these things always hit my goal.
    Chlorine is another story! This pool has always had a huge appetite and even with no swimmers and cooler weather it doesn't seem to be any less. I seem to have to add a gallon a day or more to keep my level at 7.
    I was coming and testing the water before closing and the PB always had at least five pucks in the chlorinator at a time and the level was always 1-2.
    My pool sits in full sun from around 9 am until sundown so I know it will take more but I see folks on here with similar size pools use a lot less than I do. Is this normal?
    My CYA is at 40 because I know someone is going to ask
    16x32 IG rectangular 21,800k new vinyl liner 2014, Triton II TR 50 sand Filter, Pentair 3/4 hsp whisperflow pump, 3 returns, TF100 test kit w/speedstir. Maytronics s 300i robot.
    38,524
    Re: Huge chlorine appetite
    If your chemical dosages are always overshooting, sounds like the pool may be smaller than you think and you should lower the # of gallons in PoolMath.
    What is your CYA level? Post up a full set of test results.
    FYI, it is normal to lose 2-4ppm of FC everyday. I a pool your size, that would be 66-132 oz of 8.25% bleach. So, one 121oz bottle each day could be normal.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,202
    What are your current test readings?
    Support the site
    Jun 2014
    Rogers, AR
    428
    I verified my size with the liner installer and he gave me a copy of the measurements and we measured the pool three times after moving in. I wanted to make sure I understood everything about my pool LOL
    My test results from yesterday
    FC 6
    CC 0
    CYA 40
    TA 120
    PH 7.5
    30,432
    Chlorine is consumed by two things.........sunlight (which you have minimized by having 40 CYA in the pool) and organics. The inescapable conclusion for your excess chlorine consumption is organics.....even though you may not see them.
    The solution is to SLAM your pool by following the article in Pool School precisely. If you do it right, this SLAM procedure will kill the organics and your chlorine consumption will return to normal.
