Results 1 to 13 of 13
Thread: Alternatives to polyquat?
    Victor's Avatar
    Girard, OH
    38
    Hello all, I'm in day 2 of my slam before closing and I pick this up at the pool supply store did not see polyquat. Will this be ok or should I try to find polyquat? Also do I need to let my FC drop before adding algaecide? Thanks in advance!!
    ImageUploadedByTapatalk1411411051.511149.jpgImageUploadedByTapatalk1411411062.393276.jpg
    IG, steel walled vinyl liner, approx. 18000 gal. swg ( Hayward salt system), gas heated, with 250 lb sand filter and 1.5 horse pump.
    38,275
    Re: Alternatives to polyquat?
    We recommend polyquat 60 because it seems to be the most effective. Others may work, just not as well.
    Victor's Avatar
    Girard, OH
    38
    Thanks, should I let FC drop before adding it? I've heard that high chlorine levels could effect algaecide in some way?
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    You should return it. It has very little algaecide.
    hth Aglae Guard MSDS say it has 5 to 15 % of the active ingredient: Alkyl (C12-C18) dimethyl benzyl ammonium chloride 068391-01-5
    http://householdproducts.nlm.nih.gov...nds&id=1031002
    A recommended algaecide (60%) has 60% of the active ingredient:
    http://householdproducts.nlm.nih.gov...nds&id=3026001
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Victor's Avatar
    Girard, OH
    38
    Thank you so much!!
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    I would wait until you FC is halfway between shock and normal. The key to opening to a clear pool is to close when the water temperature is below 60.
    You can get a recommended one via Amazon:
    http://smile.amazon.com/Kem-Tek-KTK-...ds=polyquat+60
    Karen
    Victor's Avatar
    Girard, OH
    38
    Thanks guys I'll do some calling to see if any other pool store has it.
    38,275
    Please add your location (City, State or City, Country) to your profile as described HERE as it will help us help you.
    daleyfolk's Avatar
    Jul 2014
    Boise,Idaho
    51
    I ordered mine off amazon. My pool store doesn't carry it, so I ordered it from amazon.
    17.5 K gallons (16x32) vinyl inground pool with 1 hp pump and an old Triton sand filter. >20 years old. New 2015 Rheem gas heater. TF-100 Test kit. Little red robot and a Pool Blaster Max.
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    I always use Amazon. It is difficult to locate and always twice the price of Amazon.
    Karen
    Victor's Avatar
    Girard, OH
    38
    Sounds like a plan!
    previous owner left pool chemicals and there are 2 bottles of algaecide 50. should i throw that away and buy polyquat 60 or use it this year and start using the polyquat 60 next year? thanks!
    Greenville NC
    14,657 gallons IG vinyl pool 14x28
    1HP A.O. Smith Pump Polaris 9550 sport robotic cleaner
    Pentair Tagelus high rate sand filter 04C TA-60/60D
    Mar 2007
    San Rafael, CA USA
    12,082
    Algaecide 50 is a linear quat so while it works as an algaecide, it can also cause foaming and it also breaks down more quickly from chlorine so has noticeably higher chlorine demand. Up to you whether you want to use it -- you could try it and if you don't like it then can discard it. I presume you are only talking about using it for closing the pool, correct? Algaecide is not needed when you are maintaining the pool at the proper chlorine level relative to the cyanuric acid level (i.e. following Pool School recommendations).
