Thread: Zodiac Watermatic L-2
    michaelrbanks's Avatar
    Sep 2014
    Cibolo, TX
    89
    I'm considering an automated liquid system & found the Zodiac Watermatic L-2, basically because all our equipment and valve automation (Aqualink) is Jandy / Zodiac. Is the system worth it? Are there drawbacks? Any advice is greatly appreciated!
    16,661 gal IG PebbleTec w/ Spa; 60 ft2 Jandy DE filter, 2 HP Jandy Variable Speed pump; 2 skimmer; 400K BTU Jandy heater; Polaris Sport; opened 9/15/14; TF-100 test kit
    Sep 2014
    Cibolo, TX
    89
    Re: Zodiac Watermatic L-2
    Bump?
    38,528
    Welcome to TFP!!!
    Do you need 2 pumps? Those are likely basically the same as Stenner pumps that many other member use, which are likely cheaper. I am not sure what integration would need to be done with the Aqualink, usually it is just a timer.
