Thread: Is CH important in AG Pool?
    Due to the volume of information that I have been reading over the past few weeks I need clarification as I thought that I read somewhere that the things I should be concerned with in my AG pool are FC, CC, PH, and CYA. Is that correct or should I be testing all of them several times a week?
    Here is my test result from today.
    Water Temp 77.1
    FC-2.8 (already added bleach to bring up to a target of 4)
    CC-0.2
    PH-7.4
    CYA-50
    CH-60
    TA-120
    David (Pool Newbie)
    Johnny Weissmuller 18x52 AG Round (approx 8,600 gal), 1 HP Pro Line Pump, Model #SD10-1N11CB, Hayward Dream Line High Rate Sand Filter, Model #S190TSCP (45 GPM Flow Rate) with Vari-Flo XL Valve, Model #SP0714TX, Taylor K-2006 Test Kit with Speed Stir.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Is CH important in AG Pool?
    Quote Originally Posted by cybercop2u View Post
    Water Temp 77.1
    CC-0.2
    PH-7.4
    CYA-50
    CH-60
    TA-120
    You only worry about CH in a vinyl pool if it gets too high, so you downat to test it occasionally.
    FC, CC & pH daily
    TA weekly or so
    CYA beginning of swim season and then again in the middle or if you change a lot of water for some reason.
    Also, it appears you are using 25 mL sample for 0.2 ppm accuracy. You can go ahead and use 10 mL sample for 0.5 ppm accuracy. It will save you reagents and is close enough for us.
    Support the site
    Thanks for the clarification as well as the prompt reply. I've come so far in such a short time and am very thankful for the wealth of knowledge and the willingness of others to help those of us who are new to TFP in gaining both knowledge and confidence.
    David (Pool Newbie)
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    One thing I'd like to comment on is your FC target. You already fell below your min for your CYA level. Your min for your CYA level is 4. You should use Pool Math ranges and that would be a target FC of 7-8 and never below 4. You get some wiggle room at that FC target so you don't fall below your min.
    Everything else looks good and don't worry about your CH unless it's very high. 😎
    Jeff
    Thanks Jeff-I failed to pick up on that and will make the adjustments on poolmath and adjust accordingly.
    David (Pool Newbie)
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Good job. I'm pretty sure you don't want to SLAM the pool. Better things to do ! 😎
    Jeff
