Thread: Removing Spa's Air blower
    Aug 2014
    Spring, TX
    7
    Hey guys,
    I purchased a home about two weeks ago with an attached spa / 20,000 gallon pool.
    The spa has four return jets which are just basic pool eyeball return jets, and one return jet which is actually plumbed into the pool return (I'm guessing to make sure the water doesn't get stagnate). It right now has an older 1 1/2 hp air blower on 2'' PVC pipe approximately 10 feet from the spa. During the pool inspection before buying the house, the inspection noted some issues with the blowers wiring, which was somewhat fixed by the old owners; and apparently the "bearings were going bad" and he recommended getting a new blower.
    Now that i've had some time to get a better feel for the pool, and read a little more on this site, i'm considering removing the blower entirely, as the distance between the spa and the intake is literally about 10', and the when the blower is on its not only loud, but it bubbles tons of water out of the spa. I usually leave both the pool and spa suction and returns open when I run my pump and SWG so that I can turn over the water and properly chlorinate it. If I remove the blower, i understand i may have some issues with bubbles when I don't want bubbles.
    What i'm wondering is can I just cap the top of the 2'' PVC, or place a jandy no lube valve at the top to stop the airflow?
    Thanks!
    Spring TX, 20,000 gallon in ground plaster pool, about 30 years old, attached spa, Raypak RP2100 heater, Whisperflo WF-26 Pump, Hayward Pro Grid DE Filter, Circupool SI-45 SWG
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Re: Removing Spa's Air blower
    I have a spa with no blower. The pool builder felt that it was not needed due to the fact that my spa water is at the same height as the pool and its a short run. I added a Jandy valve to the air supply so that I could close off the air to allow the spa to heat quicker. It all works well, but I don't have near as much "bubble action" as spas with a blower. So based on my experience I would say it should work OK.
    chiefwej
