Results 1 to 7 of 7
Thread: Air Supply Cyclone Liner Vac/Blower
    jimsky's Avatar
    May 2014
    Long Island, NY
    60
    I just finished closing my pool for the 1st time using an Air Supply Cyclone Liner Vac 3HP 120V 3-Stage, instead of my 26 gallon Craftsmen compressor. The Cyclone was well worth the purchase. Instead of doing "tank dumps" and having to wait each time for the compressor tank to refill, I had all the air I needed...continuous at the flip of a switch. The real test was blowing out the main drain. The bubble column the Cyclone created in the deep end was WAY more intense than using the compressor. If you are thinking about buying one for closing I highly recommend it.
    19,200 Vinyl IG, Hayward 1HP Super Pump, Hayward DE-2400 Filter, Stenner 45MHP10 with 15 gallon tank, Dolphin Nautilus, Roof Mounted SunGrabber Solar Panels with separate 3/4HP pump and self-designed solar pump controller. Stand alone 4 person MasterSpa hot tub.
    Apr 2013
    Central Massachusetts
    174
    Re: Air Supply Cyclone Liner Vac/Blower
    In addition to the cyclone, what parts did you have to buy to adapt it to your skimmer or filter?
    26,000 gal 18x36' IG Vinyl Pool - Hayward S244T Sand filter - Hayward Tri-star 2-speed 1.5HP pump - Goldline Aqua Plus SWCG and Controller with Tcell-15 - Aquacomfort 125K BTU Heatpump - Hayward Color Comfort 4.0 LED - Zodiac MX8 suction cleaner - TF100 test kit
    My Build thread
    jimsky's Avatar
    May 2014
    Long Island, NY
    60
    Skimmers I use a shop vac to suck the water out, very thoroughly...add antifreeze and install a gizmo.
    To blow out the jets, returns and main drain I made an adaptor that allows me to pressure my system from the pump/filter side. I got a spare filter pump basket cover for my pump. I drilled a hole in the top large enough to put a 1.5 inch PVC fitting: threads on one side and regular "glue" fitting on the other. Install fitting on pump cover, use PVC cement, screw on "nut" on inside of cover. Then I glue it up (both sides) with JB Weld for good measure. Glue in a short length of 1.5" PVC pipe and it's done.
    Use a rubber coupler to connect the Cyclone (you can see the coupler on my Cyclone photo above) and you are good to go.
    Vector's Avatar
    Mar 2014
    Southwestern IL, United States
    12
    what kind of cover is that on your pool, looks very sharp. any accessories you might recommend w/ the liner vacuum? thank you Sir.
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,264
    Vector:
    Jimsky created a cover like mine. He has a Hayward Super Pump (In his signature). I had a friend cut the circle out and it worked like a charm. Closed off the return side and I vacuumed and blew out the skimmers. There was literally no water left. Plugged with Gizmo's and called it a day. Closed MD and worked on return jets and they were all open (all 8 of them) and used goggles to see what I was doing. The MD was last. Winterized the filter as well.
    My thread below will show the cover and all parts needed, assuming you have a Hayward Super Pump Square Lid. Also plugged the pump basket with black rubber plugs as extra insurance in the event the Jandy Valve fails over the winter.
    Modified Cover for Housing
    Modified Cover for Hayward Super Pump for Closing Swimming Pool
    Winterizing your filter:
    WINTERIZING
    1. Completely drain tank by unscrewing drain cap at base of filter tank. Leave cap off during winter.
    2. Depress Vari-Flo control valve handle and rotate so as to set pointer on valve top between any two positions. This will allow water to drain from the valve. Leave valve in this "inactive" position.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Vector's Avatar
    Mar 2014
    12
    what kind of pool cover is this? is it self-supporting? i like it. BTW, i bought the cyclone, i'm gonna use it inthe next couple days. Thanks for the picture. Vector.
    jimsky's Avatar
    May 2014
    Long Island, NY
    60
    The cover is a mesh LoopLoc cover.
