Thread: slamming question
    Aug 2014
    Lake Jackson,Tx. 45 miles south of Houston
    44
    slamming question
    I am in the midst of slamming my pool. Trying to get the FC up to 18 (according to the chart) if I am reading it correctly. CYA is around 45.
    Please correct me if I am wrong.
    My question is what do I look for during slamming? What is my objective? Once I reach my objective, then what?
    Thanks in advance for any help.
    13,500 gallon pool without a spa Inground
    Pool built by previous owner in 1995 but replasterd in 2008
    DE filter (pentair FNS plus 48,Challenger 3/4 hp pump,In line chlorinator (switching to liquid bleach)
    Using TF-100 pool testing kit
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: slamming question
    The objective is to kill all the bad stuff in the water. To do that you get the FC level up to shock level and keep it there as long as it takes to meek the three objectives:
    CC is 0.5 or lower;
    You pass an OCLT (ie overnight FC loss test shows a loss of 1.0 ppm or less);
    And the water is clear.
    What you should be looking for may be different depending on what caused you to start the SLAM.
    When all three are true, you are done SLAMing and can allow the FC to drift down to normal levels.
    You should read the directions on SLAMing your pool in the How To section of Pool School.
    Support the site
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Review the SLAM Process and when you have some specific questions don't hesitate to ask. Do you have one of our recommended test kits ?
    If you think your CYA level is closer to 50 than 45 use 20 as your shock level.
    Jeff
