Thread: Shocking and Pool cleaners
    Mar 2010
    Houston
    37
    The lady at my local pool store told me to remove my Polaris from the pool for 24 hours after I shock. She said this would extend the life of the Polaris because the plastic tubing and parts get bridle faster when exposed to high chlorine levels.
    Thoughts?
    Houston
    ~20,000 inground plaster pool
    1.5 HP Hayward
    Sand Filter
    Jun 2014
    860
    Re: Shocking and Pool cleaners
    I guess that depends on what "shock" is and how high your free chlorine concentration goes. No one here can answer you because we do not use one-time "shock" products nor do we condone their use. We follow a different methodology than the "advice" you get at pool stores. I put "advice" in scare-quotes because most pool stores give false, misleading, inaccurate and often wrong advice.
    So the question for you is this - are you willing to dump the pool store and start taking control and responsibility for your own pool or are you sticking with the pool store?
    if you are indeed using the TFP SLAM method than your cleaner is safe at shock FC levels as described in the article on FC/CYA relationship.
    Jun 2011
    Long Beach, CA
    2,790
    I would expose the cleaner and run it for a few hours at shock level and then remove it.
