Results 1 to 8 of 8
Thread: Why does the pressure drop?
    May 2014
    Peters Creek Alaska
    15
    My "clean" pressure sits at 10 psi. When I add DE, it drops to 6. After a hour of filtering, it'll drop some more and more. I thought that when you added DE, the pressure would rise. Could my pump have issues also?
    27' AG 17,000 gallon
    Hayward 220 Sand Filter
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Why does the pressure drop?
    Pressure should rise. You may be adding the DE too quickly and it is clogging the impeller or something else in front of the filter or even the pressure gauge.
    Mark
    May 2014
    Peters Creek Alaska
    15
    Quote Originally Posted by mas985 View Post
    Brand new gauge so I guess I'll take the impeller apart and take a look. I do add the DE fast but I thought it would still not clog the impeller. That stuff is so fine I'd of thought that it would just flow through. We'll see in a few minutes.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Did you add the DE before the new gauge was installed? DE can plug the small hole in the gauge.
    Also, you should probably read this: http://www.troublefreepool.com/conte...-a-sand-filter
    Mark
    May 2014
    Peters Creek Alaska
    15
    I added the DE about a week after I installed the new multiport. I actually have 2 gauges on this and they're both equal.
    I just took the impeller apart and found nothing in there. I used an air compressor and blew the lines all out, so that tells me their clear. I do notice a couple of drips on the pump side of the multiport. Could the leak cause me to have a wrong reading? I just added DE again and the pressure dropped again.
    So confusing.
    mas985's Avatar
    Pleasanton, CA
    11,737
    It almost sounds like the pressure gauges are after the filter instead of before the filter. That is exactly what would happen if the filter was installed backwards.
    Mark
    May 2014
    Peters Creek Alaska
    15
    The gauge are after the filter. Holy ****!!! This is too funny if that is the issue!!!
    mas985's Avatar
    Pleasanton, CA
    11,737
    The DE is causing a clog somewhere before the pressure gauges so that can mean one of two things. The clog is before the filter (e.g. multi-port, pump, suction line) OR the gauges are after the filter and the DE in the filter media is causing a lower pressure at the gauges.
    Mark
