Page 1 of 2 12 LastLast
Results 1 to 20 of 39
Thread: I am an idiot and listened to Leslie Pools. Now I need help please!
    Aug 2014
    Phoenix, AZ
    24
    First of all, this is an awesome thread and there is so much useful information, but I'm feeling a little overwhelmed so decided to post to see if someone can provide quick advice or direct me to a relevant thread.
    I have a 13.5 IG pebble-tech in Phoenix, AZ (I will add this to my signature line). We have had some heavy rains here that seemed to have messed up some levels and turned the pool green. I had someone come out and "fix" the pool last week, but after $150 later, the pool turned blue, but stayed cloudy. The green pool returned today even after brushing and making sure there were tabs (I realize that this might not be enough now after reading your forum).
    I got my levels tested today at Leslie's. (I know I need to buy the right tester - right now I am using strips from HD - but where do I find this on the forum?). Here are my levels according to Leslie's:
    FC = 0
    CYA = 90
    TA = 40
    PH = 7
    Base Demand 4
    Copper = 0
    Iron = 0
    TDS = 3900
    Phosphates = 450
    Their recommendation is to drain the pool. This doesn't seem like a good option to me. First of all, I don't know how to drain. Do I just backwash? Do I just dump it in the alley? How do I hook it to a septic line? I am in downtown Phoenix and there is not a drain in site to pour it down. Can I adjust these levels without draining or will this be a constant problem?
    The other big mess up is they told me to use granular shock (which I think is dichlor) and add more pool tabs (probably also dichlor). Did I seriously mess things up now? I added 8 cups of baking soda (to bring up the alkalinity), 4 tabs and and 2.5 pounds of granular shock (all at their recommendation). I have been running the pool pump for about 3 hours. When do I test the levels again? Should I take it back to Leslie or are the strips okay and go from there or can I buy the recommended test kits in store?
    Thank you all for your help.
    38,285
    Re: I am an idiot and listened to Leslie Pools. Now I need help please!
    Welcome to TFP!!!
    You certainly need to invest in one of the Recommended Test Kits. The TF-100 is the best value and can be bought from poolsupplyworld.com which might get here a little faster than from tftestkits.net
    If that CYA is correct (and would not surprise me if you are using a lot of tablets), then you really do need to replace around 50% of the water to get that back in range. Then to clear up the pool you have to follow the ShockLevelAndMAINTAIN Process.
    The Dichlor and more trichlor tablets are just making your CYA problem worse ... and they are also what is making your pH and TA crash low.
    The test strips are worthless and likely you should just throw them away. Leslie's testing is not much better ... you need a drop based test kit.
    How much Pool School have you read? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Jason has fairly well covered it, so all I can say is welcome to TFP.
    Support the site
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The thing that concerns me the most out of your description is that the pool turned blue, cloudy blue is not a normal color for pools and may indicate some type of metals in your water although green or brown are more common colors we see with copper or iron in the water. Blue tends to be something more exotic, and since we don't know what was added last week this could be a side effect of some magic potion.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    You will need to decide if you want to join the thousands of pool owners who use the tools and methods recommended here, and learn how to manage your own pool. That means accurate testing with a good test kit learning that you only add what the pool needs, and rejecting any advice from pool stores. It starts with ordering a good test kit (the TF-100 is highly recommended), and reading the info contained in "Pool School". That's the button on the upper right of this page.
    chiefwej
    Aug 2014
    Phoenix, AZ
    24
    Thank you all for your comments. TF100 is already on its way. I decided to not waste any more money on chemicals, wait until the test kit arrives and then drain, but my concern now is how to drain.
    I bought the house in February and have no idea how old the water is or how to tell what drain equipment I have. So how do I accomplish draining? I know I have a sand filter. Do I drain all at once? Where do I get the pump? Can I backwash for a while? Where do I dispose of water? I live in downtown and there is not a drain in site, just an alley and a very small space in my yard. Do I test after refilling/during the process? Any tips would be very helpful.
    Thanks!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    If you can post photos of your equipment we may be able to offer more help, also does your pool have a floor drain, and if so are there valves so you can isolate it from the skimmer. Worst case is you will need to buy a cheap $50 submersible pump from somewhere like harbor freight. It would also help if you post general information about your pool in your signature, like size, type of equipment, type of pool, etc.
    Would it be possible to use the water from the pool to water your yard over several days?
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,497
    WELCOME! You are on the right track!
    Find TFP-done!
    Ask questions-done!
    Order test kit-done!
    Now post up some pics using a site like photobucket or such.
    Draining-Isaac has you covered.
    Also post pics of your pool. Take a pic of your ladder or steps. Once you start working on your pool again you will want to take daily pics to see your progress and let us watch with you.
    We can get you clear again. Just let us know what you are doing and we can guide you.
    Oh, one more thing. Go ahead and look around for your best price for bleach or liquid chlorine. Some people find it at walmart (greater value bleach) and some people find it at their pool store (the only thing they buy from there LOL). I find mine at my local ACE Hardware up the road. Make sure you look at the %. Walart will be 8% or so. Pool store may be 11% so........
    Good luck!
    Kim
    Aug 2014
    Phoenix, AZ
    24
    You guys are awesome! I feel so much more confident now. Pics soon to come and good description of equipment and pool soon to come!
    poolnoob.ca's Avatar
    May 2014
    Georgetown, ON, Canada
    277
    Do you have a sewer grate on the street you could run a hose to for drainage? a hose such as: http://www.walmart.com/ip/HTH-50-Poo...-Hose/20703032
    32,000L Fibreglass Leisure Pools IG 12.5'x23'x5' Pump: AstralPools BX1 1.0HP
    Filter: AstralPools ZX-310 SWCG: AstralPools VX7T
    Heater: Hayward H250FDN Test Kit: TF-100
    Jul 2014
    Peoria, IL
    389
    Or buy a cheap vacuum setup and set that on the bottom and set pump to waste. That's what I do if I need to drain some water off. But I have 40 acres to "water".
    But first determine if a drain and refill is the way to go.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    Sep 2014
    Modesto CA
    16
    Your house should have a main drain you can access from the outside - get underwater pump - run the exit hose into the outside drain - and you are good to go...
    Quote Originally Posted by middlear View Post
    Thanks!
    Jan 2014
    Buckeye AZ
    807
    Quote Originally Posted by wingman1973 View Post
    where would the roto rooter guy/gal go if he had to clear the drain between your bathroom and the street? Look outside for a 3-4" black plastic stub and cap, often with a square socket on it.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    May 2014
    Franklin, NC
    9,184
    Remember, not everyone is on a gravity sewer system. Mine is a grinder pump that pumps through a 2" line to a pressurized forced sewer main. Nowhere to pump...
    Support the site
    Aug 2014
    Phoenix, AZ
    24
    So, I'm finally ready to switch to this method. After much rain and electricity going out, I am finally draining the pool after the algae grew. I can't seem to attach all the pics I took. I bought a sub pump from HF which was much cheaper than HD. I am going to do a chlorine wash and scrub the pool. Do I also need to do an acid wash? How do I get rid of the calcium buildup? Will CLR work?
    Jul 2012
    Tallahassee, FL
    30,497
    And you are OFF! On the way to having a clear pool!
    Kim
    Aug 2014
    Phoenix, AZ
    24
    I don't know how to post all of my pics. I have compressed them, but cannot seem to upload them. Any suggestions. I have a Triton II sand filter. Anything special I need to do with that? Do I need to buy a pressure washer?
    swoopman's Avatar
    Jul 2014
    Annapolis, MD
    213
    See this for help with posting pics:
    http://www.troublefreepool.com/threa...screenshots%29
    TF-100 Test Kit
    22,000 gallon, 20x40 kidney-shape IG plaster pool built in 1986
    Nautilus NS-36 DE filter, Hayward Self Prime Super Pump 1HP
    Polaris Automatic Pool Cleaner, PB4-60 3/4 HP pump
    38,285
    To post more/larger pictures, you either need to raise your storage allotment by Becoming a TFP Supporter or follow the How To Post Pictures tutorial.
  20. Back To Top    #20
    Aug 2014
    Phoenix, AZ
    24
    You guys are so responsive. I really appreciate that. I created a flickr account and will start a new thread to be able to use the full text editor. I will post my pics there and link to this thread.
