Thread: Help with pool losing water
    Sep 2014
    Maryland
    2
    Hi all,
    First I hope this this the right sub forum for my question, if it's not, I'll move it somewhere else.
    I drained my pool this August and repaint it. During the time of painting I didn't see any active cracks or leaks in my pool.
    Then I put a newly bought hydrostatic valve (bought from Ebay) in the main drain instead of a solid valve cap.
    After doing all this I decided it was too late to reopen the pool so I just filled the water to the half way and close the pool.
    Today I opened the cover just to check out and find out I lost about more than a foot of water during the past month.
    The pool was OK last year.
    So I assume I did something wrong this year.
    My question is:
    What's the possibilities out there?
    Is it because I turn some valves incorrectly? I didn't seal the main drain properly? The hydrostatic valve is faulty?
    Basically I'm wondering what should I do to begin with?
    I really appreciate your opinions, thank you!a
    38,475
    Re: Help with pool losing water
    Welcome to TFP!!!
    I would suspect the last thing you touched ... that being the new hydrostatic valve.
    Sep 2014
    Maryland
    2
    Thank you jblizzle!
    Since there are still a few feet of water at the deep end. Can I wait till next pool season to drain the pool and check the hydrostatic valve?
    I don't know how much damage it will cause if I just leave it there as it is.
    Welcome to TFP!!!
    38,475
    Depending on your ground water level, leaving the pool empty could be a problem. Although the valve should prevent issues. Why did you think you needed to install a hydrostatic valve?
