Thread: Borate test kit. Where in Canada..?
    Daf-Tekno's Avatar
    Sep 2014
    Calgary / AB
    70
    Hi People,
    Where can I order a borate test kit from, that will ship to Canada?
    I hear the LaMotte strip test is good, but as ever in this sphere, it isn't available in or shippable to Canada.
    Any suggestions will be followed.
    Thanks kindly.
    Jacuzzi J480 (2008) 1700 litres, Balboa ozonator, Delta EZ-18-120 UV lamp via custom 6-way 2-tier timer solenoid array, 2 x Waterway 4HP main pumps,
    1 x Aqua-Flow 1/15 HP circ pump, ChlorMaker IL SWG, SmartSeal + Roxul skirting insulation, 8' x 8' ThermoFloat Spa blanket, 100" x 100" Gator coverall
    nofa93's Avatar
    Sep 2013
    Montreal, Canada
    46
    Re: Borate test kit. Where in Canada..?
    You can order from http://tftestkits.net as it is not a Taylor product. They can ship it to you. Apollo pools(http://piscines-apollo.com) used to offer his own Borates drop test but He has just recently stopped doing Business. I was able to order it just a couple days prior to his retirement.
    20,000 Gallons Vinyl 16x32 Inground with Stamped concrete decking. Hayward Sand Filter. DIY Diaphragm pump injection system. K-2006C Test Kit.
    450 Gallons Standalone Acrylic CALSPA 2006.
    Canadians, Get your test kit here!.
