Results 1 to 7 of 7
Thread: Calculate motor run time
    My pool details are in my signature. I need help in calculating pool motor runtime. i.e how many hours I need to run at low speed and how many hours at High speed... Thanks a lot
    11000 Gallons, Cartridge Filter, UG, Plaster, Shasta pool, filter model Hayward C4030, Pump Motor Emerson 1-1/2HP Full Rated EB2977T, Pump model Northstar SP4010NS
    38,262
    Re: Calculate motor run time
    Read this, ask questions: Determine Pump Run Time
    Ok thanks, based on that link, I will run the motor for 6 hours at low speed and 1 hour at high speed, Hopefully that will work.. Please confirm?
    Smykowski's Avatar
    Sep 2011
    3,065
    Start from there and see what happens.
    We're not trying to be evasive, it's just that you pretty much have to use trial and error to see what works.
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    You very likely could run less time, but each pool is different. I have a slightly bigger pool than you, and a smaller pump, and most of the time I get by with 6 hours a day, 3 in the morning, 3 in the late afternoon, all on low. That helps me skim off all the pollen. In June, when the cottonwood trees are giving off their cotton, 24 hours is not really enough time, but then I would have to empty the skimmer several times a day, so I keep with 6 hours and also do some manual skimming. From July onward, I could get by with 4 hours or less, all on low. If you have lots of plants that are shedding leaves and other stuff or a lot of dust blowing, you might need more.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    mas985's Avatar
    Pleasanton, CA
    11,737
    fatboysam, with that pool size you shouldn't need more than about 4 hours. I run my 20 k pool for 1 hour on high speed and 3 hours on low speed.
    Mark
    Shirker's Avatar
    Jul 2014
    Athens, GA - USA
    132
    I usually let mine run on low all day long to keep the water warm up and I try not to run it at night hoping that it will retain as much heat from the day as possible. But now that it is getting cool, I can run it as little as 2 hours on high each day. Just enough to circulate the chemicals and skim the ants off the top.
    TF-100 | 13.6k gal (24' Round) AG | Chlorine | Sand Filter | Two Speed Motor | Installed June 2014 | Last Opened April 24 2016
