Results 1 to 12 of 12
Thread: Loop lock cover
    Aug 2014
    Mechanicsville, md
    29
    Loop lock cover
    Got a quote today from a local company installing loop lock. Quoted for 20x40. It's a kidney type shape. Estimate was like 3600 installed. Sound high but what do I know.
    Is that about the going rate. I'm in Maryland.
    22,500 Gallon, In Ground, Plaster, Jandy DE Filter, Jandy Pump, Built in Fall of 2014, Filled by water truck and partially by well.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Loop lock cover
    It seems like most places charge about as much for the installation and measuring as they do for the cover. If you are handy, you can install it yourself and save about half.
    Jun 2012
    New Jersey
    5
    Re: Loop lock cover
    I am in NJ. Got quoted $2600 - no installation (I already have old cover and needed a remake). Pool is an "L" shaped rectangular with steps 20x40.
    1) 20x40 IG concrete (approx. 35K gallons)
    2) 1 HP Pentair WhisperFlo pump
    3) DE filter (48 sq. ft.)
    4) Polaris 280 cleaner (with booster pump)
    5) DIY solar heater
    swoopman's Avatar
    Jul 2014
    Annapolis, MD
    213
    Re: Loop lock cover
    I'm in Maryland and in August of last year was quoted $3000 to replace the 20x40 loop loc cover (no installation or measuring).
    TF-100 Test Kit
    22,000 gallon, 20x40 kidney-shape IG plaster pool built in 1986
    Nautilus NS-36 DE filter, Hayward Self Prime Super Pump 1HP
    Polaris Automatic Pool Cleaner, PB4-60 3/4 HP pump
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Loop lock cover
    It's been a few years, but I saved quite a bit by doing my own measuring and install, and ordering the cover online. Instructions on how to measure a non standard pool for a custom fitted cover are pretty straight forward and install was easy.
    chiefwej
    May 2013
    Fort Lauderdale, FL
    423
    Re: Loop lock cover
    $3,300 for mine installed. I think they keep the measurements at loop-loc so you can order a replacment without having to re-measure.
    I think it's worth it. My mother-in-law tripped and fell right on it, didn't get hurt or wet. With little kids and lots of trees it's a life saver.
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    Jul 2012
    Cary, NC (Raleigh)
    69
    Re: Loop lock cover
    If I recall we got ours for around $2700 installed and getting them to include the pool closing process at time of install last fall.
    Its definitely worth the peace of mind with 2 little kids running around and dogs in the backyard.
    18x30 Freeform In-ground Vinyl Lined. 11,500 gallons.
    4 returns, 2 skimmers, 2 main drains.
    Hayward TriStar 1hp 2-Speed Pump. Hayward S244T Filter.Hayward Goldline Panel + SWG.
    Polaris 280 cleaner. AquaComfort 75k BTU Heatpump
    TF-100
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Re: Loop lock cover
    Our LoopLoc cost $3000 installed 9 years ago- Pool was closed for 8 years with the cover on it and if you look at it today you would think its only a year or two old. Made really well!
    Our pool is teardrop shaped, about 25' at the wide end and 40+feet long.
    Quick update on LL install costing.
    Since we had all new pavers installed this year we needed the anchors to be installed and even though i have a hammer drill i didn't want to deal with my wife if she didn't like the outcome
    The original installer wanted $500 and that was with reusing the old 37 anchors. it sounded like a lot of money but again i didn't want any issues with the new pavers. He came yesterday with a helper at 8AM and finished at 2PM.
    An hour of that was to winterize the systems. He used the biggest Bosch Hammer drill i've seen with a 4 point diamond bit. I don't know how these pavers are made but I learned some new curse words yesterday.
    I researched new anchors and LoopLoc's are about $15 for the anchor and tube with a need to bore a 1" hole. The anchor he supplies(and the ones i had form his last install) are 12" solid steel with the anchor welded onto one end. It uses a 3/4" hole. He says he has them made up by a local welding shop which i think is true since i cant find them any where. I think i did ok with the costing as the wife is happy and it was a bear of a job.
    Re: Loop lock cover
    I had a 38' Leisure fiberglass pool installed about 4 years ago. I was using blue "Walmart" style cover for winters. Decided purchase a safety cover, vinyl, so no extra water/light would get in the pool. I contacted several online companies that sell the LoopLoc Ultra II and was told I would have to make a template, send it in, wait for a price, etc, etc. I even asked if there wasn't already a template for the particular pool I had and was told no. I contacted Leisure and they were no help, didn't even answer my call, just had a local pool company call me. When I told them I was a DIY I never heard from them again. A friend of mine in GA told me about poolcovercenter.com, he had just received a cover from them. I called them, explained what I wanted, and the agent, Karen, offered to call LoopLoc and ask if they may have a cover for my particular pool. You guessed it, yes, they had made a cover for my pool model and didn't need the measurements. Then I found out the price was the same as a "standard" cover. Ordered it, and received it within a week. A big shout out to Pool Cover Center, great customer service, saved me money and time....
    N Virginia
    -Leisure Moroccan 38' Fiberglass
    -19,800 Gallons
    -Pentair EasyTouch 4 w/IC40 Chlorinator,VS3050 Pump, Clean&Clear Plus 320 Cartridge Filter,Prowler 720 Robot Cleaner
    -1 Skimmer/ 3 Returns/2 Drains/2" Piping
    -3 Fiberstar Pal Treo LED lights/Wirtran
    -TF100 TestKit
    Sep 2009
    Frederick County, MD
    185
    Re: Loop lock cover
    We have the same pool, who did your install?
    Quote Originally Posted by Gunnert View Post
    Jim
    Southern Frederick County, MD - Leisure Moroccan 38 Fiberglass Pool - 19,800 gallons
    Pentair 1.5 hp 2 speed pump - Cartridge filter - Dolphin robot - TF-100 Test Kit - SWCG
    Jul 2014
    Hope Mills, NC
    567
    Re: Loop lock cover
    YIKES!!! I can get a safety cover for my 16 x 32 with steps for about $800 delivered from Amazon and a Loop Loc brand is only $1500. That means you are paying a whole lot of money for somebody to drill holes.
    DIY install includes buying a new hammer drill and a bit, I don't count that because I love a new tool!
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    May 2013
    Albany, NY
    59
    Re: Loop lock cover
    Quote Originally Posted by Griswald View Post
    Is your 16x32 a rectangle? I know that comparing Rectangle to Kidney / Freeform isn't really apples to apples. Freeforms take more time on the cutting floor, and have 3'x3' strap spacing, rather than the 5'x5' for geometric pools. Also 16x32 Rectangle is pretty common, so if your pool doesn't include any raised walls / cutouts, its probable that this was a stock, inventoried cover made ahead of time. Just food for thought.
    I order Loop Loc covers quite a bit in season (B2B pricing), and I don't think Pappascw is getting hosed TOO much.
    Eric Adams, Technical Specialist, Radiant Pools
