Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: DIY IG started in Cincinnati, OH
    Jul 2014
    Northern Cincinnati, OH
    56
    After months of research, I have finally started my pool. Ordered a 20 x 40 Mt Loch/Lagoon/Deer Creek from Poolwarehouse.com. So far everything seems decent quality. I was very nervous about buying from the internet. My only real issue with the order so far was with the shipper. Was supposed to have lift gate service and be able to use a pallet jack to get it up the drive way. At last minute they called said the skids were too big for lift gate and we had to unload by hand. Luckily I was able to get some last minute help to unload mid day on a Thursday which was a little tough. Getting the Poolwarehouse guys on the phone was a little harder than I would have liked at times, but they were nice when I did get them.
    I hired an excavator that came highly recommended, and this guy was like a surgeon with his backhoe. Unfortunately we did just clip some underground drainage lines but I knew that was a possibility and they should not be too bad to fix.
    jjwalker's Avatar
    S. Louisiana
    198
    Re: DIY IG started in Cincinnati, OH
    Looks good wilsjay...from what I glean from the IG vinyl pools the dig can be the most important part.
    Pics, pics, pics...we love pics!
    18x36 vinyl / sport pool 5.5' deep / 1.5hp Tri-Star 2spd / Hayward c3030 325 sqft cartridge / ~15k gal / TF100
    cwescapexlt4x4's Avatar
    Jul 2014
    Litchfield Park, AZ (PHX metro area)
    461
    Nice start, looking forward to the progress.
    Chris - aka cwescapexlt4x4
    (Build 8/26/14 - 10/17/14) in-ground Presidential Pools 15K gallon salt water pool Pentair Inteiliflo pump, Regal Blue Pebble, Clean & Clear filter, in-floor cleaning,
    LED light, 3' sheer spill, 2 benches, large Baja step. / Pergola by Booth Built 19W x 14D // Outdoor Kitchen, W/Primo grill and BBQ Coach kit for the island.
    30,403
    Welcome to the forum.
    Jul 2014
    56
    @jjwalker you are dead on. Other than the plumbing repair for the drain line they clipped while digging I have had to do surprising little hand shoveling. The plumbing repair was more than enough though! I bought a spud bar at lowes and that was key for that job.
    So a friend stopped by later that same night the kit was delivered and the excavator finished and offered to help me set the panels down in the hole. So far that was the hardest part of the job manual labor wise, but 2 of us got them all in hole in about 45 minutes. The only pic I have is from the next night when I was doing the plumbing repair after work.
    Jul 2014
    56
    Todays progress
    Had 2 buddies help me set the walls, pull the plumbing, etc. I greatly underestimated how many screws would need to be shot on this project! I actually can't believe how fast it went together and took shape. The excavator made the job cake. Very little hand shoveling!
    Jul 2014
    56
    Finally got all of my plumbing ran, the steel steps bolted in, the lights (2), the skimmers (2) , the returns (5), the main drain, the overflow, a backwash line and the footer drain in place. Tomorrow hoping to have to footer poured. After that only 1 small piece of downspout drain line to repair then ready for back fill and electrical.
    One item to note: When buying PVC fittings, make sure you don't get the ones that say Drain or Not For Pressure. I did not see this marked anywhere on the fittings, but it is on the boxes/bins at home depot/lowes if you read closely. The 1-1/2inch PVC fittings for pressure are made by Lasco at Lowes. The lowes closest to my house is a small one and does not carry these, just the drain/not for pressure ones.
    Jul 2014
    56
    Tonight started working on electrical trench. Rented a walk behind trencher that digs a 6in x 24in trench. So far it is not going well. My soil is rock hard clay with no rocks at all and the machine is struggling and not getting the trench deep enough. Going to try another pass tomorrow and hoping for some better results...
    Jul 2014
    Peoria, IL
    389
    Quote Originally Posted by wilsjay View Post
    Tonight started working on electrical trench. Rented a walk behind trencher that digs a 6in x 24in trench. So far it is not going well. My soil is rock hard clay and the machine is struggling and not getting the trench deep enough. Going to try another pass tomorrow and hoping for some better results...
    We had a similar issue in central Illinois. We waited until the day after ewe got rain and trenched then. Was much easier. Could probably do the same with a sprinkler??
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    Jul 2014
    56
    Thanks @bdex. I am not sure what piece of equipment I should have rented, but what I got was not the one for the job. I originally wanted to have the excavator do it, but he only had a 3 foot bucket on his back hoe. I got a buddy over this morning that helped me clean it out by hand and start pulling wire and running conduit. I have a couple of spots still to clean out but got it in for the most part.
    fyi- this is the machine I rented:
    Jul 2014
    Peoria, IL
    389
    The one we rented had a fixed blade thing on the front but similar. Looks like you got the job done. Did you run 1.5" pipe?
    Central Illinois
    Jul 2014
    56
    1.25" conduit with (4) 2 awg insulated wires for a 100 amp sub panel. Put the wire in the conduit as I went. That part was not bad at all even on the 90 deg elbows. I was expecting much worse actually.
    Jul 2014
    Peoria, IL
    389
    Nice. I went with 1.5" because the local big box store cannot get their **** together and stock all if the 1.25" pieces. L good though. I did a 50 amp sub panel with 4 #6 THHN and ran an extra 20a circuit in there.
    Central Illinois
    Jul 2014
    56
    Finally got all my electrical conduit run and wire pulled for the sub panel and lights. Also dug 2 post holes and set two 4x4 posts to mount my sub panel. I am hoping to finish up my bonding tomorrow and get my trench inspection Monday/Tuesday and then start back filling.
    I will admit the electrical materials are costing quite a bit more than I anticipated. I am over $230 just for three breakers and that is after shopping around! I had previously just priced the wire and sub panel (as I figured/guessed that is where all the money would be) both of which I thought were fairly reasonable but seems to be nickle and dime-ing me for all the other little pieces.
    Late addition to the mix the wife wants a slide now. I have to pull a line for the water supply for that and figure out exactly where to stub it up. The manufacture's instructions not the best to pinpoint this!
    I will be glad to be out of the mud/dirt and trenches here soon I hope!
    Jul 2014
    Peoria, IL
    389
    Better now than after you pours concrete like at my house. Makes it easy to say no I guess??
    Central Illinois
    Jul 2014
    56
    @bdex - That sux. Hopefully you got it straightened out!
    Here are some pics of my bonding. I am planning on tying the wires I have stuck in the are with a piece of red duct tape to the rebar I will put into the concrete deck.
    Jul 2014
    56
    And finally backfilled
    Planning on starting the concrete decking area later this week. Doing cantilever coping. Glad to have gravel instead of mud! Thanks Mike.
    Jul 2014
    56
    After 2 SOLID weeks of rain (litterally every day) plus a week of drying out the yard and pumping out the deep end, finally poured the decking today.
    Tomorrow will be finish dressing out the concrete and removing forms (sub-contractor), and I will hopefully be hooking up the filter pad equipment. Hoping to get vermiculite on Monday and drop the liner on Tuesday.
    Jul 2014
    56
    The vermiculite floor went in today. Weather permitting liner goes in tomorrow. Here is are some before and after pics:
    Before:
    During:
    [/url]
    [/url]
    After:
  20. Back To Top    #20
    Jul 2014
    56
    I am certain this will probably be of no interest to anyone else, but I am a bit OCD on the plumbing setup as I worked as a laborer for my uncle who is a plumber through high school and college. I am also certain there is an obscene amount of over kill in this setup as well. All plumbing is homerun in 1-1/2 PVC with a pentair never lube type shut off valve and a backwash line. I went with an over-sized sand filter, 1.5HP Hayward super pump, Hayward SWG, Hayward automatic chlorinator (came with the kit and installed as a backup if the salt cell fails), and a Hayward heat pump. My electrical setup I went with a 100 amp sub panel.
    Let me know if anyone has a good way to label all these valves, better than a sharpie.
