Thread: Keeping CL at optimal levels during the winter
    GeneS's Avatar
    Aug 2014
    Columbia, SC
    9
    I am keeping my pool open for the winter here in SC. The previous owner told me the SWG will not produce CL when the water temps dip below 60. What is the best way to at clorine using the BBB method since I have no way to maintain a constant supply of CL? I really do not want to add tabs like he did but will if I have to. Do I just add bleach as needed and test frequently?
    Gene
    30K gal, IG, Gunite, Sand Filter, Pool installed 2000, Hayward T-cell-15 SWG (3 years old)
    Polaris 9350 Robot, Hayward S244T 24" sand filter, Hayward 1 1/1hp single speed Northstar pump
    Hayward Gas Heater
    38,455
    Re: Keeping CL at optimal levels during the winter
    The easiest is to just add bleach. Although when the water is that cold, the chlorine will not be consumed very quickly. You will have to experiment, but you may only need to test and add once a week ... and if you have a cover, maybe less than that.
    GeneS's Avatar
    Aug 2014
    Columbia, SC
    9
    Thanks for the input. I assumed this was the case thanks for the reassurance. I really love not being tied to the pool stores since visiting this site and learning so much over the past few months.
    Hayward Gas Heater
    Nov 2013
    Fort Worth, TX
    114
    Could you please elaborate on this? After reading lots of posts on this site, I was under the impression that FC consumption had much more to do with sunlight (UV) than anything else including air and water temperatures. I do understand that algae is much more likely at higher water temperatures, but if no algae is present, then the water temperature is really not a factor. If all this is true, then I would assume that the only reason that less FC is consumed in the winter is due to the fact that the days are shorter?
    30,000 plaster in-ground pool with spa; 2.5HP single speed Centurion pump; Raypak RP2100 propane heater; Polaris 280 with pump, waterfall with separate pump, Triton II commercial sand filter; TF-100 test kit w/ SpeedStir
    38,455
    There is always some amount of organics/algae in the water that is being killed and oxidized. The colder water slows any growth down significantly. But, you are also correct that the shorter days and less intense sunlight also contribute to the reduced FC consumption.
    Mar 2007
    San Rafael, CA USA
    12,082
    It's both. If my pool is covered by the opaque cover all the time, I still lose around 0.7 ppm FC per day at 88F and this is temperature dependent. It's mostly chlorine oxidizing the cover, some chlorine oxidizing CYA, and the rest oxidizing anything else it can find in the water or elsewhere. This loss is very temperature dependent and slows to around a 1 ppm FC loss every 1-2 weeks when the water temp gets to 50F or so.
    You can readily distinguish between the loss from sunlight vs. the temperature dependent loss by measuring the loss overnight when there is no sun on the pool. And yes, during the winter the loss from sunlight drops not because of temperature but because of the lower angle of the sun and usually having cloudier days.
