Thread: New agp Owner need plumbing help
    Jun 2014
    port saint lucie
    9
    Hi, I'm new to the site and I have found this site to be very helpful! We have a Vogue Discovery 21' Round pool. It has two return holes and the skimmer. The old Returns have the threaded nut to tighten them down but someone previously used glue.
    They measure 2 1/4" outside diameter. Is the hayward sp1023 the right ones to get? They all say 1.5" threads. I'm sure that's inside thread diameter but how am I sure it will have 2 1/4" outside diameter to fit the hole in the pool wall?
    Jun 2014
    port saint lucie
    9
    Re: New agp Owner need plumbing help
    anyone?
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    I am no expert but I think 1.5" is correct. Can you post a picture of your current ones both from the inside and the outside of the pool?
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    Jul 2014
    Bastrop, Louisiana
    199
    Here is the specs for the SP-1023:
    DIMENSIONS: BODY: FACEPLATE DIAMETER: 3-1/2" THREAD LENGTH: 1-7/16" INSIDE BODY: 1-1/2" FEMALE PIPE THREADS (ABOUT 1-7/8" ACTUAL INSIDE DIAMETER) OUTSIDE BODY: 2" MALE PIPE THREADS (ABOUT 2-3/8" ACTUAL OUTSIDE DIAMETER) GASKETS: ALL ARE APPROXIMATELY 3-7/16" OUTSIDE, 2-7/16" INSIDE
    Specs were found at: http://www.inyopools.com/Products/07501352030406.htm
    That seems to be the right one that you need.
    Randy H.
    Intex 18' X 48"
    G.A.M.E. Sandpro 75 Sand Filter (Single Speed 3/4 HP, 75 lbs sand, 2650 GPH, 7-way valve)
