Thread: Some confusion on the directions for R0867
    Sep 2014
    Dawson MN
    13
    Cool Some confusion on the directions for R0867
    I have the instructions for this reagent but my question is when you use a non-chlorine shock to shock the pool, how long do you wait to use this reagent to get and accurate FC reading, and CC reading. Do you test right after you shock the pool, do you wait an hour, or do you wait 6hrs (which is our turn-over rate)? I work at a school so we use the non-chlorine shock so they can use the pool all day. Any help would be appreciated. We use the Taylor 2006 test kit. Thanks
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Some confusion on the directions for R0867
    You can use this reagent any time to achieve an accurate test for FC and CC. The R-0867 reagent eliminates interference of MPS (most non-chlorine shocks are this compound) in the FC and CC test. You can also test for MPS if you have the proper reagents. See the instructions for these tests here:
    http://www.taylortechnologies.com/pr...er&Number=5806
    Isolated Spa - 345 Gallons
    Sep 2014
    Dawson MN
    13
    Thanks a ton t his was very helpful.
