Results 1 to 14 of 14
Thread: FC drop
    dabuddy's Avatar
    Jul 2008
    Grand Rapids, MI
    97
    FC drop
    Hey guys, member me? I did the Bacqua-goo conversion a couple of weeks ago, went on vacation and now back and maintaining my crystal clear pool. I have a question about my FC consumption. I understand that FC is only consumed by sunlight or organic matter.
    Sunday when I returned from vacation my CC was 0.5 (6 PM) and yesterday (Monday 8 PM) my CC wasto 1.0 so I brought my pool to shock level last night (FC 16.5 - took reading about 1/2 hour after adding bleach). ph 7.2, CYA 60.
    This morning when I woke up I did a reading and my FC was 18.0 (actually went up!) CC was 0.2 (very very light pink; I don't think I needed a full drop to bring it back to clear so I estimate 0.2). pH 7.2. When I got home today from work I took a reading and my FC dropped to 8.0 and CC was 0.5. Swimmer load today was 3 teens for 2 hours and they didn't splash enough to raise the pH.My question/concern, with a CYA of 60 and FC of 18.0 this morning is it normal to drop 10 ppm today over a 12 hour period?
    What should my actions be, wait, shock, other?
    I just added 4 lbs, 12 oz of Borax just now to try to get pH up from 7.2 to 7.5.
    Chris
    18'x36' (Depth: deep 8'6" shallow 3'6") rectangular 27,000 Gallon Vinyl In Ground. Hayward self-priming super pump 1 HP 2600x5-96, Hayward Pro Series High Rate 24" 7-Position 300 lb Sand Filter, Hayward H250 Natural Gas 250,000 BTU Electronic Ignitiion - Digital Readout Heater, Hayward Navigator 925V PoolVac.
    Converted Baquacil to Chlorine - should have done it sooner!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: FC drop
    I would say that's probably within normal limits....best way to check is to do an overnight comparison. Record tonights result, and compare it in the morning, see if your FC is holding in the dark....
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Re: FC drop
    The following are some quotes taken from other threads about FC loss:
    Sunlight losses are a percentage, so you lose more the higher the initial level. Disinfection loses are constant relative to the starting level, so it doesn't matter what you starting level is. For most pools sunlight loses predominate, but a heavy bather load could make the disinfection losses significant. There are some more complex effects if your level is low enough to allow algae to get started.
    Quote Originally Posted by mas985
    Chemgeek will probably correct me if I am wrong but first order extinction rates are based primarily upon the percentage of chlorine. So for example at a CYA of 30 ppm, I lose about 50% of the chlorine during the day. It doesn't seem to matter much what the level starts at but the extinction rate of 50% is pretty constant.
    However, what I have found is that if you double the CYA, the extinction rate goes down by more than 50% so you come out ahead with higher CYA.
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    Re: FC drop
    Chlorine loss to sunlight should have been 30-40%, call it 6 ppm. But you also had six person hours of swimming, which is a significant bather load. That could easily account for the other 4 ppm lost.
    dabuddy's Avatar
    Jul 2008
    Grand Rapids, MI
    97
    Re: FC drop
    Thanks guys for the quick and clear responses. I'm still learning but I get it...
    Chris
    dabuddy's Avatar
    Jul 2008
    Grand Rapids, MI
    97
    Re: FC drop
    ph looks to be about 7.7 now.
    Chris
    dabuddy's Avatar
    Jul 2008
    Grand Rapids, MI
    97
    Re: FC drop
    Readings:
    10 PM last night:
    FC - 10.5
    CC - 0.5 (very, very light pink though)
    TC - 11.0
    pH - 7.7
    7 AM this morning:
    FC - 10.5
    TC - 11.0
    pH - 7.7
    This is my baseline for finding out how much FC I lose today due to sunlight and bather load.
    Chris
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Re: FC drop
    I think a CC of 0.5 can be ignored because sometimes even though the water appears clear with a pink haze sometimes that extra drop will make it actually turn clear. I always miss that extra drop when I'm testing!
    Also IF after adding your drops you let it sit a few minutes and thrn looked at it again it will turn slightly pink
    Les
    Helpful Links:
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: FC drop
    If in doubt, you can use a 25 ml water sample instead of 10 ml and then each drop of titrant will represent 0.2 ppm instead of 0.5 ppm.
    dabuddy's Avatar
    Jul 2008
    Grand Rapids, MI
    97
    Re: FC drop
    Cool, next time I do the test I'll use a 25ml sample.
    In case anyone is wondering, my readings at 8:30 PM today after 2 swimmers for 2 hours and mostly overcast all day (sun came out mid-afternoon):
    FC - 4.5
    TC - 5.0
    pH - 7.6
    Chris
    Butterfly's Avatar
    South Carolina
    10,045
    Re: FC drop
    Quote Originally Posted by dabuddy
    FC - 4.5
    TC - 5.0
    pH - 7.6
    Okay, unless I missed something, your CYA is still 60? Then your MINIMUM FC should be 5 and you just reported 4.5ppm. With a CYA of 60, your Min is 5 & Target is 7 to 9, so you are going to have to add enough chlorine each evening to keep you above your minimum FC between doses! You may have to shoot for 10 or 12, depending on your pool's daily use (organics, bather load, sun, etc.) so that you do not drop too low.
    It is not a good idea to get too close to your Min FC for your CYA, it can bite you when you least expect it! (Don't ask me how I know this )
    So, what did you increase your FC to tonight?
    You're done SLAMing when:
    dabuddy's Avatar
    Jul 2008
    Grand Rapids, MI
    97
    Re: FC drop
    Yup, CYA is still 60. i get FULL sun all day. I was shooting for 10 FC tonight. Since I don't want to drop below 5 perhaps I can yank the kids out a 1/2 hour earlier tomorrow!
    I added 2.25 gallons according to the PoolCalculator to get it from 4.5 to 10. With your advice I will now get it to 12. I just added 3/4 more gallons. I ran out of R-0871 so I now am guessing I ordered replacement Sunday night so I should get it soon.
    Thanks a bunch for your advice!
    Chris
    Butterfly's Avatar
    South Carolina
    10,045
    Re: FC drop
    So glad you added some more! Sure don't want you to yank the kids out early!
    Re: FC drop
    yea, good luck with THAT one!!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
