Thread: Bleach Accident
    Bleach Accident
    Hi,
    Made the mistake of adding Clorox Splashless to my Hot Spot Relay. Foam everywhere. Looks like Im going to do a refill tomorrow. Is there anything extra that needs to be done, to make sure the Splashless stuff won't be an issue with the refill? Also adding pics of my set up before the accident.
    Thanks!
    20,000 GAL, 16 X 32 IG Vinly Pool, Sand Filter, & 1.5 HP Hayward - Hot Spot Relay Hotub
    N. Mississippi.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Bleach Accident
    The foam will eventually dissipate. If you scoop it up it will get removed faster.
