Thread: Should the skimmer stay on all the time?
    Sep 2014
    Las Vegas/NV
    10
    If my options for one of my pool levers on my pump says, pool main drain, or skimmer; which one should it be on? Or should it be in the middle?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Should the skimmer stay on all the time?
    Sounds like a 3 way valve. During normal operation you'll want it in the middle so both are open. You may want it on skimmer only for more suction when manually vacuuming.
    Isolated Spa - 345 Gallons
    Sep 2014
    Las Vegas/NV
    10
    Ok, does one use more water than the other? I'm just trying to figure out why my water bill went up a hundred this month and that was the only variable that changed.
    Feb 2014
    Central Minnesota
    5,080
    Water bill would only go up with water filling, not circulation. Do you have an auto fill mechanism on the pool?
