Thread: How to remove yellow staining above water line
    Hi,
    This is the second year of our doughboy above ground pool. This year some portions of the liner have turned or have a yellowing stain which is above the water line and seems to be where the sun hits it directly. It is not around the entire pool, and it is not below the water line, so I wouldn't think one of those stain removers that you add to your water would work. I don't want to use something harsh or that would mess up the liner design. Anyone have any suggestions on what I should do? Getting ready to shut it down for the year, but I want to clean that off before doing so.
    Good old fashion elbow grease did not work.
    Thank you!
    Cheryl
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Re: How to remove yellow staining above water line
    I too have a doughboy and a stain builds up like that with mine. Mr. Clean Magic Erasers are a God send. Buy the bucket of them if you can find them. If not, buy a couple of them at least. Just hop in and go around the pool. It's actually fairly easy to get it off.
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
