Thread: Quaternary Ammonium Compounds?
    mariane's Avatar
    May 2012
    Southeast Michigan
    305
    Post Quaternary Ammonium Compounds?
    My sister is taking down her pool and gave me all her pool chemicals. Included in the "pool stored" stuff, she also gave me a jug of Champion Pool Winterizer which had no list of ingredients on it. When I googled it, it came up "Quaternary Ammonium Compounds" as the ingredient. Further searching resulted in websites and pdf documents
    http://www.champakinc.com/pdf/pool_p...ool_winter.pdf
    http://www.sheltermedicine.vet.corne...singBleach.pdf
    http://www.nalco.com/documents/Produ..._Compounds.pdf
    Is there any benefit in using it or should I toss it?
    Thanks for your input,
    Mariane
    16 x 28 Doughboy Mystic Garden AGP with 7' deep end (used expandable vinyl liner) ~11,800 gals. Deep end main drain. Thru-the-wall skimmer, one return at deep end. Media Master 150# sand filter. Doughboy PowerPak II pump, 1 hp. Pentair MinimaxCH 150m natural gas heater. Polaris 65 when it feels like working . TF-100 test kit. No longer 'pool stored' 6 years and counting. In sunny but fickle metro-Detroit.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Quaternary Ammonium Compounds?
    I would take them to your closest HHW facility and get rid of them. They are algaecides, just not very good ones because of the formulation and low concentrations.
    Isolated Spa - 345 Gallons
    mariane's Avatar
    May 2012
    Southeast Michigan
    305
    Thanks JVTrain.
    I should have figured it, that she was "pool stored" when they told her she needed it.
