Results 1 to 7 of 7
Thread: Re-level Kayak Pool
    Sep 2014
    galena ohio
    5
    Re-level Kayak Pool
    Hello,
    I moved into a house last year with a 16'x32' Kayak rectangular pool. The pool was originally built on a raised base to level it properly. One side of the pool sits on the natural ground while the other side of the base is probably a foot above the natural ground level. The pool has settled over time and has areas with as much of a 4.5" difference. Most areas appear to be 2-3" of difference from the highest point. I am planning to drain, re-level and install a new liner in the spring before I open it. I am looking for tips or recommendations so that I can start planning. I am particularly concerned about trying to re-level it with that much difference. Would the preferred method be to raise the low areas and block or should I dig the high areas in? If I do raise and block, what can I do to help prevent those areas from having the floor wash out after installing the new liner? I can attach pictures if needed.
    38,470
    Re: Re-level Kayak Pool
    Welcome to TFP!!!
    We say that anything out of 1" of level is not recommended, so it is good that you are planning on fixing this.
    Generally, you always want to dig down the high side so that the entire pool is sitting on undisturbed ground. If you try to build up an area and do not do it properly, it will settle as you have seen.
    Sep 2014
    galena ohio
    5
    Thanks for the response. So if I were to dig it out and lower it as you suggest, would I be causing any problems by burying the walls that much? I believe the Kayak walls are made of wood so should I be concerned if they are down in the dirt and could possibly start to rot.
    38,470
    I have seem some members who do not backfill the dirt onto the pool, they add a little retaining wall with a few feet between it and the pool. So it is not really "buried".
    If you build-up, you will need to have some form of barrier to hold the fill in place and you need to be sure that is it properly compacted. Usually you want to use a fill called crusher run or something like that which compacts nicely every few inches.
    Aug 2011
    Cochranville, PA
    228
    When I did mine I dug about a foot bigger on the high side. Then I took another 2 or 3 feet at about a 30 degree angle. So you still have a foot to stand on if you are on the out side of the pool brushing or getting leaves out. The reason I put the angle was so I could put stone landscaping around it. I also feared a "cliff" might be dangerous.
    1) The size of your pool in gallons 4440.
    2) The type filter you have is an Intex 28651EG Krystal Clear 3000 GPH sand filter
    3) If your pool is an AG (above ground)
    4) Intex 15 by 48 metal frame.
    Southeastern, Pennsylvania.
    Casey's Avatar
    SW PA
    10,453
    Buy crush n run. Its also called 2A modified. They build roads out of it. Rent a plate compactor and go in 3" lifts and compact it. You can build it up to level and reset the pool at its current with no problems. That's your only option at building up.
    May 2012
    Montville NJ
    545
    Quote Originally Posted by Casey View Post
    You are only going to find 2A mod in quarries in and around PA. That is a PA DOT specification. The original poster is from Ohio. 2A is also an exact specification, and tested by the State, so it can end up costing more than plain old run of the mill (crusher) DGA.
    The stuff goes by a variety of names - DGA (dense graded aggregate), QP (Quarry process) or Crusher Run (the total run of what comes out of a crusher). I see Crush n' Run or Crush & Run on these forums quite a bit - but I have never heard it at a quarry or on a construction site.
    Thanks
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
