Results 1 to 15 of 15
Thread: Water feature comes on with pump.
    May 2014
    Turlock, Ca
    8
    For no apparent reason (I didn't change any valves or the timer setting) the water feature came on when the pump started in the morning and ran with it all day. The timer/system is set so the pump/filter goes off at 5pm and the water feature runs from 5 - 6pm.
    Jerry
    11k, IG, pebble, PentAir vs pump, Pentair Quad DE 100 filter, Pentair IC-40 SWCG, Pentair MasterTemp 400k BTU/hr heater, Pentair EasyTouch Remote controls, Kreepy Krauly Sand shark pool cleaner. Built 8/13. TF-100 test kit.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Water feature comes on with pump.
    Is the water feature on a valve with an actuator? The switch might be off.
    Mark
    May 2014
    Turlock, Ca
    8
    Yes, it's on an actuator and the switch is on.
    Jerry
    mas985's Avatar
    Pleasanton, CA
    11,737
    Have you confirmed that the actuator is still working and the switch is in the correct location?
    Mark
    May 2014
    Turlock, Ca
    8
    Well - as so often happens - pump just went on and waterfall didn't. So we'll see tonight at 5 if it works.
    Don't know if the actuator is working (or how to tell) but the switch is in the 'on 1' position. There is also an 'on 2' and 'off'. I haven't moved the switch (no kids) so I'm guessing it's in the same position it has been.
    Jerry
    mas985's Avatar
    Pleasanton, CA
    11,737
    There should be a button on the controller which will toggle the actuator. Try on and off and make sure it moves and stops in the correct position.
    Mark
    May 2014
    Turlock, Ca
    8
    Moved the toggle to 'on 2' (from 'on 1') the the waterfall came on. Moved the toggle back to 'on 1' where it had been and the waterfall stays on.
    Jerry
    mas985's Avatar
    Pleasanton, CA
    11,737
    You might want to check the controller too.
    Mark
    May 2014
    Turlock, Ca
    8
    What do you mean by 'Controller'?
    Jerry
    mas985's Avatar
    Pleasanton, CA
    11,737
    The device that turns on and off the pump and controls the valves with the timers.
    There should be a button on it that directly controls that particular valve.
    Mark
    May 2014
    Turlock, Ca
    8
    Ok, got that, thanks. But in the interim I turned the pump off to see if the valve would close, and now everything is off - pump won't go back on, nothing on the control box/panel, swg, etc.!
    Jerry
    mas985's Avatar
    Pleasanton, CA
    11,737
    Check the breaker for the controller. If that is not tripped, then the problem could be with the controller power supply.
    Mark
    May 2014
    Turlock, Ca
    8
    Ok - up and running. Button on 'control box' by equipment and button on remote won't turn the waterfall off.
    Jerry
    mas985's Avatar
    Pleasanton, CA
    11,737
    Sounds like a problem with the controller.
    Mark
    May 2014
    Turlock, Ca
    8
    Thanks for your help.
    Jerry
