Results 1 to 12 of 12
Thread: Sources of acid demand
    Oct 2007
    Valrico, FL
    542
    I would like some help in identifying some possible sources of acid demand in my pool. I have a salt pool with a SWCG. First my most recent numbers:
    FC 3.0
    TC 3.2
    CC 0.2
    pH 7.6
    TA 80
    CH 370
    CYA 80
    Borates 30
    Salt 3100
    Temp 90F
    I have installed an acid feed pump that maintains the pH more or less constant. Anyway I am adding about 32 oz of 31% acid per week. Some sources of acid demand that I know of:
    1. CO2 out gassing. This is a possibility. However my TA has not changed 10 ppm in over a month. It is my understanding that CO2 out gassing at a constant pH will tend to decrease the TA. Using my Colorq it appears that the TA has changed by less than 5 ppm in a month.
    2. Plaster curing. Another possibility. However the pool was filled at the end of October. It is now August so the plaster is about 10 months out. I would expect that the acid demand from curing plaster to be rather small.
    3. Rain. I live in west central Florida. In the summer we have very high rainfalls. I am pumping out 1 to 2 inches of water from the pool each week. I don't know what effect this would have on the acid demand, but is causing me to add salt and CYA
    I am open to any more ideas.
    Thank You,
    Donald
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Sources of acid demand
    Quote Originally Posted by dschlic1
    FC 3.0
    TC 3.2
    CC 0.2
    pH 7.6
    TA 80
    CH 370
    CYA 80
    Borates 30
    Salt 3100
    Temp 90F
    This is probably the cause. Even though TA has not changed does not mean that the PH will not rise. Acid will lower the TA as well as PH so if there is anything adding TA to the pool, and there are a lot of sources, then the PH will continue to rise and TA could remain the same. This happens in my pool. If you did not have some other source of TA from somewhere, over time the addition of acid will continue to lower TA.
    Even though the plaster may completely cure, there is a small film of solid plaster dust which can take a while to complete dissolve. Mine took well over a year before it was completely gone and I had to add quite a bit of acid.
    I'm not sure but I would think that a basic rain is somewhat unusual. Rain is usually acidic.
    Thank You,
    Donald
    More to add:
    4) Fill water - This may not impact you as much given the amount of rain you are seeing. I have very high TA fill water which tends to keep the TA high and raises the PH.
    My guess is that the plaster is still adding TA to the water and adding acid only keeps it steady. The SWG will cause the PH to rise unless the TA is kept really low.
    Mark
    Guest
    Rain aerates the water and will cause CO2 to outgas, btw.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by waterbear
    Good point, completely forgot about that.
    Mark
    Oct 2007
    Valrico, FL
    542
    I forgot to add my SWCG settings. I have an AquaPlus unit with the T-15 cell. The current SWCG setting is 10%. During the week I run the filter from 10 am to 7 pm, and on weekends from 8 am to 7 pm. The AquaPlus has a two hour cycle time. So on weekdays I have five cycles of 12 minutes each (one hour total run time) and on Saturday and Sunday I have six cycles of 12 minutes for a runtime of 72 minutes each day. The T-15 cell is rated to produce 1.45 lbs of chlorine per day, so for a weekday the daily production is 0.06 lbs of chlorine, and on weekends is 0.073 lbs. Total weekly production is 0.45 lbs of chlorine.
    A conversation about the chemistry of SWGs has been split off to this topic. JasonLion
    Oct 2007
    Valrico, FL
    542
    What other processes other than plater curing can raise pH and TA?
    Mar 2007
    San Rafael, CA USA
    12,082
    The pH can rise from outgassing of carbon dioxide with no change in TA. The TA can rise from evaporation and refill of water since fill water has some TA in it and usually the fill water doesn't affect the pH very much. So a combination of the two can lead to both pH and TA rising over time.
    As you mentioned, the curing of plaster can increase both pH and TA. Corrosion of pool plaster (from a low saturation index) can likewise lead to a rise in pH and TA.
    Other than the above, the only other thing I can think of is chemicals (e.g. pH Up or Alkalinity Up or Borax or Lye) or stuff that gets into the pool of sufficient quantity that is alkaline.
    Jul 2007
    Rockville, CA
    99
    Since rain can cause sufficient aeration to increase pH levels, I would assume the aeration provided by a spillover spa or sheer descents would have a similar effect. I have lots of wind where I live, and would assume this would have a similar effect, as well.
    20K inground gunite w/ Aqua Logic automation and chlorination Sta-Rite 400 K natural gas heater and cartridge filter 2 HP pump 1.5 HP spa bubbler for spillover spa 1 HP dedicated Letro Legend cleaner
    H2O: two parts Heart and one part Obsession. ~Author Unknown
    Mar 2007
    San Rafael, CA USA
    12,082
    You are correct. Increasing the rate of outgassing of carbon dioxide will increase the rate of pH rise. So a higher TA, lower pH, or more air-water mixing such as aeration from rain, wind, spillover, fountain, waterfall, shower, splashing, returns turned up, will all increase the rate of pH rise.
    Oct 2007
    Valrico, FL
    542
    Well it sounds like I am up the creek on reducing my acid demand. I have not filled the pool from tap water for over two to three months. The only fill is from rain. I also have not added anything to the pool expcept salt and CYA.
    Guest
    Try dropping your TA to 60 ppm and increasing the borates to 50 ppm.
