Thread: Leak near hot tub controller
    My hot tub is leaking from one of the hand-tightened couplers next to the controller (see picture). Is there a user-serviceable washer or part in this area that I could replace? I have the tub drained, but wanted to check here before I tried to loosen the coupler to see if I can fix it. I turned it as tight as I could, but it still leaks.
    ~32k gal, plaster, 3HP Intelliflo, 100 sqft Quad D.E., EasyTouch SWG, Gas/solar heating, Waterfalls x2
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,198
    Re: Leak near hot tub controller
    The pipe at the bottom of the controller? If so those are the heater connections and I'll bet if you take off the leaking one you will find an "O" ring inside that seals it. Tighter is not necessarily better with "O" rings, no cuts and proper lubrication when installing helps.
    Support the site
    Thanks. Yes, it is the pipe that runs through the bottom of the controller. I will go ahead and un-couple the connections (might as well replace both sides) and get new o-rings. What do you use to lubricate them upon installation?
    May 2014
    Franklin, NC
    9,198
    Quote Originally Posted by garymwyatt View Post
    I'm not being a smart***, but "O" ring lube. Comes in a small tube. I've seen it at Home Depot & Lowes in the seasonal pool section.
    Support the site
    Jul 2014
    Peoria, IL
    389
    Looks like a balboa controller and the white ones with two screws on each one are the heater unions. They leak all of the time. And yes. Replace both, they are cheap. And if you have to go to the pool store to get o-ring lube, do so. Don't use Vaseline or silicone. It breaks down the seals.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    Thanks to all. Will follow your instructions and report back.
