Results 1 to 10 of 10
Thread: Filter Pump is tripping breaker
    Aug 2008
    Western Connecticut
    5
    The filter has been working fine for years. Today I go out to turn it on and it instantly trips the breaker. I reset and it does it again. I checked everything visible and no sign of damage, etc. I am fairly talented electrically and I have a pretty good electrical tester. Anyone have any ideas how to diagnose this problem? FYI: It rained pretty good last night.
    Also, it was very difficult to figure out how to post. Was there a better category to post this? Couldn't find any electrical/pump troubleshooting category.
    George
    Moved to Swimming pool Equipment - Molson
    Inground Pool 40x20 Vinyl Liner
    Hayward DE Filter and pump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Filter Pump is tripping breaker
    Is the breaker GFCI or a standard breaker?
    Aug 2008
    Western Connecticut
    5
    Quote Originally Posted by JohnT
    Looks as if it is a GFI (It has a "push to test button on it"
    SW Indiana
    9,199
    Quote Originally Posted by gmessier
    I'd bet you've got water someplace in the wiring.
    Aug 2008
    Eastern Washington State
    11
    G'day All,
    If it is a GFCI breaker, check the connection to the neutral/ground in the box. If it loses its neutral/ground, it will trip constantly. But, breakers were never designed to be constant use switches, so you could easily have a bad breaker. Good Luck, TJ.
    21' AG, 10,000 gal, 22" Sand Filter, 1 hp pump
    Jul 2008
    144
    It sounds like you have electricity going to ground. You need to disconnect the wires from the circuit breaker and check for continuity to ground. This can happen from a damaged wire or water in the conduit. With the wires disconnected from the circuit breaker, see if the switch will stay on. You can also disconnect the wires from just the pump and see if the switch still trips. If the circuit breaker stays on with just the pump disconnected, the problem may be related to the pump.
    Aug 2008
    Western Connecticut
    5
    Thank you for all these thoughtful replies but they are too general for me. "Check for continuity to ground"? Can you please tell me specifically how to do that with my multi tester?
    "Check the connection to nuetral/ground in the box"? How specifically, do I do this?
    Thank you both for the effort, but I still do not have an actionable game plan ... and the water is getting ugly.
    George
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    George
    George,
    Get an electrician to check this for you. I don't mean to sound ugly, but if you don't know how to check for continuity to ground or to check a connection to the neutral bar in the breaker box, you really don't need to be trying to troubleshoot this problem. I would really hate to try to give you instructions on how to do this, only to find out you electrocuted yourself in the process (and poking around in a breaker box is a good way to do it).
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Jul 2008
    144
    I have to agree with MikeInTN; if you are unsure how to do these things, you need to get an electrician to assist you.
    Aug 2008
    11
    George
    As far as the connection to ground/neutral, there is a white wire that should come from the breaker to the neutral bar. This is the wire that is used by the GFCI to test and route the ground fault should one occur. If the wire is loose, it might present enough resistance for the GFCI to pop. Also, it could be sensing a leaky ground somewhere else, and the breaker is throwing. But, I would also like to restate this - a breaker is not a switch, and when they are used as one, they will eventually go bad........
    Good luck,
    TJ.
