Thread: Closing question
    Closing question
    After I blow out the lines from returns and skimmers, do I keep the pump, filter and the heat pump still connected to all the piping or should I keep everything disconnected until I open the pool next season?
    24 x 14 salt water inground pool
    Feb 2012
    Maryland
    400
    Re: Closing question
    I keep all piping and equipment connected. I have a make shift cover I put over the pump to keep snow and ice from packing around it but other than that my pad stays in tact.
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    May 2013
    Fort Lauderdale, FL
    423
    Connected, but all drain plugs removed. My pump has two plugs, one in the sand filter bottom, and another heater plug.
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    Feb 2012
    Maryland
    400
    Quote Originally Posted by zimm View Post
    Exactly, and all drain plugs put in the pump basket so I know where they are come spring.
