singingpond
cmbx2mom, your signature information shows that the pool was installed this summer, and your first post mentioned that you've used BBB method all along -- so, you probably haven't been adding unknown amounts of CYA via pucks or powders. If you can remember how much stabilizer you put into your (relatively) new pool, that should give you a cross check on what your CYA levels are likely to be now. Then you'll be more certain that your SLAM level for FC is high enough to get the job done efficiently.
Doing a SLAM when no one is using the pool, and you just want to close up shop for the winter, is tedious -- good luck, and I hope you get to the end soon!
