Results 1 to 14 of 14
Thread: The Pool Cleaner x4 suction float position
    Sep 2014
    Scottsdale, AZ
    2
    Hi. We just got a Poolvernugen x4 suction this afternoon and have been trying to get it to climb walls. I can't seem to adjust the floats to get it to do so. I've tried moving them farther and closer, splitting them up and removing one all together. Our pool is a 28k gal diving pool. The cleaner seems to go about 1-2 feet up most of the walls before the front falls away from the wall and it sinks to the bottom. Any tips on positions to try moving the floats to? We have it running at 13rpm currently. It moves from the deep end to the shallow end fine. Thank you
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: The Pool Cleaner x4 suction float position
    Just an FYI, it really doesn't do anything when it climbs the walls so there really isn't any benefit. The downside is that if it gets too high it will start sucking air. But the closer the float is to the cleaner head, the higher it will climb. But again, there really is no benefit that I can see.
    Mark
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    I guess its like brushing the walls, just in case algae is starting somewhere, chlorine then has a better chance on cleaning up before it take over. I think I read that here...
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    mas985's Avatar
    Pleasanton, CA
    11,737
    There is no brush in ThePoolCleaner. It only has suction so you still need to brush the walls manually. Any dirt or algae stuck to the walls would not be affected by the cleaner. I have had my cleaner for 9 years and it will climb the walls but it still doesn't obviate the need to brush the walls.
    Mark
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    So the flat disk scraping on the bottom serves just for suction, not cleaning? Thanks good to know.
    Autopilot SWG
    mas985's Avatar
    Pleasanton, CA
    11,737
    There is no flat disk for ThePoolCleaner. It looks like this:
    Mark
    Sep 2014
    Scottsdale, AZ
    2
    thanks. I still plan to brush the walls like I currently do as I don't mind doing that, it was the manual vac I hated. It was terrible and can detached every 5 seconds. We succumbed to fact that the poolcleaner probably wouldn't go up the walls as we were testing it last night, but I told my bf I was ok with sweeping so we're going to keep it. Thanks again
    Jun 2014
    860
    I have a Pentair KreepyKrauli suction side cleaner and it will definitely climb walls. The bottom pad has rubber "fingers" on it to "scrap" the surface as it moves. That being said, I still brush weekly as well. There's just no substitute for good brushing.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Sorry thought you were talking about another cleaner with the disk, I have...I do brush also, not much only places where it can't go, stairs, sun ledge. Here it is busy as always..
    Autopilot SWG
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Quote Originally Posted by littlesparkz View Post
    What kind of pool surface do you have?
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Its a plaster surface, just bought the house in March, thanks to TFP been running great. I have to say I love taking care of my own pool...really don't know more than that about the surface..I bought the MX 8 at first but returned it, just couldn't handle curved sections...
    Autopilot SWG
    Sep 2014
    Bakersfield, CA
    155
    My 4-wheel won't climb the walls unless I run it at 14+ rpm, and it makes an awful noise when it breaches the surface! Also at 14+ rpm I have to direct so much suction flow to the cleaner I don't get enough flow thru the skimmer!
    I found the best position for the floats was with the mid-point of the two floats at 6" from the top of the cleaner.
    Cheers, Peter
    20,000 gal, 52'x17' kidney shaped IG, Pebble Tec, IntelliPro P6E6VS4H-209L pump. Intellichlor IC40 SWG.
    300 sf Sta-Rite System 3 cartridge filter. Poolvergnuegen 4-wheel suction pool cleaner. TF-100 test kit.
    Jul 2014
    Haslet, TX
    19
    Took me a minute to find it, but I remember reading in the manual that the pool cleaner is actually designed to not climb walls. Look at "3. ADJUSTING WHEEL RPM" on page 7 of the manual (http://www.thepoolcleaner.com/PoolCleanerSUCTION.pdf).
    I have a 2-wheel cleaner and have been very happy with it. Hope you like yours.
    23K gal, 38' x 22' irregular, gunite, StoneScapes Mini Pebbles, 2 HP TriStar 2spd pump, 525 sqft cartridge filter, TurboCell SWG, ProLogic controller, The Pool Cleaner 2 Wheel
    mas985's Avatar
    Pleasanton, CA
    11,737
    I think that just means that it won't climb the wall at 8 RPM. At 11-13 RPM the old version will climb walls but the newer version seems to have more trouble.
    Mark
