Thread: Ideas For Closing a Gunite/Tile Pool Without Lowering Water Level?
    I have a 4 year old 16k concrete pool with a tile waterline we've opened and closed every year with no problems.
    I was trying to think of a way to leave the water level up this time by putting some kind of expansion protection in the pool just like the foam water tubes we put in the skimmers to protect the tile from ice freeze. I would also use some sealing skimmer doors to help keep them dry. Anyone done this? I'm in OKC and it gets in the 20's every winter so I need to protect the tile, I wonder if one of those cover support balls would contract with freezing...or some bigger tubes anchored to the bottom? My plaster looks nasty at the lowered waterline for months every year and I'd rather keep that nastiness on the tile!
    Jul 2014
    Berks County, PA
    206
    Re: Ideas For Closing a Gunite/Tile Pool Without Lowering Water Level?
    I would not recommend leaving the water level up on the tiles. Expansion and contraction during freezing weather could result in tile damage. I try to keep the water level below the tiles until, of course, at some point it becomes impossible to work with the level once things freeze up and / or snow and ice cover the entire pool.
    12,000 gal. Anthony IG pool; 3 ft. shallow end to 6 ft. deep end; Built 1989; Renovated July 2014 using a 10-part unexposed quartz plaster aggregate of 3 S-grade Blue, 3 S-grade Gray, 2 T-grade Blue, 2 T-grade Gray; Apollo VA-52 DE Filter; Hayward SP-2607X10 Super Pump 1-HP Single Speed; Jandy AE-Ti Heat Pump; Taylor K-2006 Test Kit
