Results 1 to 12 of 12
Thread: bleach question
    Aug 2014
    Lake Jackson,Tx. 45 miles south of Houston
    44
    bleach question
    When I go to the poolmath page it is asking for % bleach. I don't find that info anywhere on the bottle. How can I tell?
    I bought Clorox splash-less regular in a 116 oz. bottle
    13,500 gallon pool without a spa Inground
    Pool built by previous owner in 1995 but replasterd in 2008
    DE filter (pentair FNS plus 48,Challenger 3/4 hp pump,In line chlorinator (switching to liquid bleach)
    Using TF-100 pool testing kit
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: bleach question
    Look for % sodium hypochlorite on the label. Most grocery store bleach is 8.5%.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: bleach question
    Don't use the splashless version or any special versions with scents or additives. Just plain bleach.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    38,305
    Re: bleach question
    Do NOT use splash less bleach!! You need to use plain bleach. No additives, fragrances, splash less, etc.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: bleach question
    ^^^beat you!
    Re: bleach question
    Make sure that the bleach says "Regular" and "Sodium Hypochlorite.....8.25%".
    Support the site
    Wildcat's Avatar
    Jun 2013
    309
    Re: bleach question
    To either add to the confusion or to make things more clear:
    Most regular bleach used to be 6%
    The newer, so-called concentrated ones are 8.25%
    Most chlorination liquids for pool use are still bleach but 10% with a few at 12%
    Try to buy bleach at a store that has high turnover as bleach uses strength over time
    Also try and buy it from a store that does not keep it outside as temps weaken it too
    Other than that try and buy the one that is the lowest cost per ounce, bleach is bleach
    10000 Gal, IG Pebbletec, pop up cleaners,Hayward EcoStar VS, 425 sq ft Hayward Cartridge, waterfall feature
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: bleach question
    Quote Originally Posted by bponb View Post
    If we're too late and you already added the splashless... the suds will go away in a few days, after you switch to the plain stuff.
    Re: bleach question
    Lol I accidentally added splashless a few weeks ago after my husband brought it home on accident. Splashless Clorox is not a pool sanitizer. If you add it, you will have soapy bubbles for a few days. You need to buy unscented 8% bleach...typically generic store brand is $3/gallon.
    17,000 inground gunite pool finished June 2013. Pentair variable speed something or another. Polaris cleaner, inline rainbow chlorinator. Using trichlor until CYA reaches 50-60.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: bleach question
    I have seen some "splashless" that is just plain bleach in a newly designed jug that reduces the "glug, glug, glug" that splashes. Just more confusion as to what is plain bleach.
    Support the site
    Oct 2013
    Chapin, SC
    1,141
    Re: bleach question
    Most 8.25% bleach doesn't come in gallon bottles, but 121 oz.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: bleach question
    Quote Originally Posted by tim5055 View Post
    Clorox splashless bleach has thickeners in it that will cause foaming in the swimming pool. So it's safest just to avoid all splashless unless one is sure of the contents.
