Thread: Getting my CYA level down and then what?
    Aug 2014
    Lake Jackson,Tx. 45 miles south of Houston
    44
    I am currently refilling my pool as recommended to get my CYA level down. Do I then run all the tests again, plug into the poolmath chart and go from there? Just what is my next step.
    I am new to this pool thing and am wanting to get it right.
    Thanks
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,050
    Re: Getting my CYA level down and then what?
    Let the water circulate a while. Brushing helps set up some cross currents to really get things mixed well.
    Take a full set of readings and then adjust pH first, and then set the FC level appropriate to your CYA level.
    Or post the results here and wait for someone to offer specifics. It will help a lot if you fill out your signature so we know the pool surface and your chlorine source.
    Aug 2014
    44
    Just finished my sig info.
    13,500 gallon pool without a spa Inground
    Pool built by previous owner in 1995 but replasterd in 2008
    DE filter (pentair FNS plus 48,Challenger 3/4 hp pump,In line chlorinator (switching to liquid bleach)
    Using TF-100 pool testing kit
