Thread: Raypak 6350ti-E heat pump not working properly
    Jan 2014
    Fredericton, NB, Canada
    130
    Hey guys...would love some advice on this issue...I have a raypak 6350ti-E. Brand new this summer and has worked flawlessly the few times it has needed to run. However, the past 2 days, now that I actually need the heat, the compressor keeps shutting off on it's own and only the fan runs. It has plenty of flow, the ambient temperature is 55-60 F, and there doesn't appear to be any error code. Any idea what could be going wrong and how I can remedy the problem? I can get it to kick in by pressing a button on the digital display...but it kicks back out within a few minutes... It has been controlled by my hayward pro logic system and worked perfectly all summer. I have tried disabling it on the prologic and using the heaters digital controls with the same outcome. It will turn on for a few minutes, but then the compressor will shut off and the fan will run alone... We are trying to get the last week of enjoyment out of the pool, but pretty hard when we can't heat the water.
    Thanks!
    18' x 36' IG Vinyl Kidney Shape, 20K Gallon, Hayward ProLogic PLP4 Control with T-15 SWG, ColorLogic 4.0 LED Light, Hayward TriStar 1 HP Full Rated Pump, Hayward Swimclear 325 SQ FT Cartridge Filter, Raypak 117000 BTU Heat Pump, TF100 Test Kit.
    Jan 2014
    130
    Re: Raypak 6350ti-E heat pump not working properly
    So, I've found that there is, in fact, a fault code. FS, which means it's going into defrost mode which will keep the fan running and shut down the compressor. This is not supposed to happen until the ambient temperature is down to 42 F....but it has been happening when the actual ambient temp is 15-20 degrees warmer than that.... for example, it's 57 F right now, and the unit is still continually going into the defrost fault after 2-3 minutes of operation. Frustrating since this is the exact time of year that I really want to use the heat pump! Hopefully I can get ahold of someone from Raypak tomorrow...
    Is it PD, HC, or HS model?
    It states in the manual that defrost is typically 42-48, based on humidity.
    I would start with testing the ambient temp sensor. Disconnect, and test Ω reading 57 should be ~16.55kΩ
    Here's a table.
    http://www.bapihvac.com/content/uplo...stor_10-2K.pdf
    24k gallon inground vinyl liner pool, 8'-3' depth, 2 skimmers, 3 returns, basic 5 chem kit.
    Hayward: DE-60 filter, Superpump VS, AquaRite salt chlorinator w/T-Cell 15, TigerShark QC robot. Jacuzzi hot tub ~350gal. Air blower type, w/8 jets.
    Jan 2014
    130
    It is model R6350TI-E. Not the heat/cool model, heat only, with digital display. I read that it's 42-48 depending on humidity but it's going into defrost when the ambient temp is 55-60 F....humidity was around 55% give or take. Seems quite a bit premature. I'm not sure how to check the ambient temp sensor, but I'll look into it. It should be fully covered by warranty, so hopefully I can get ahold of raypak tomorrow...and go from there.
    Thanks for the feedback!
