Thread: Will CYA addition reduce ph or TA?
    amjohn's Avatar
    Jul 2008
    Rural NE Texas
    I am gradually adding granulated CYA to my pool now. I have ph of 7.2 ( or maybe a little lower) and TA of 60 using the TA-100 test. A little low, but not too bad. So, since CYA is an acid, will it reduce the TA or ph?
    28 ft round Doughboy Sand Dollar II AGP, Aug 2008: 4 ft shallow, 6ft deep end: 24K gal approx Hayward Power-Flo Matrix
    1&1/2-HP 2-SPD Pump, Hayward 27-Inch Sand Filter with a little DE -(2) 4ftx20ft Solar Bear AGP Panels w/ Goldline auto-controller, 50ppm Borates And some day, maybe this year, a DECK!!!
    Re: Will CYA addition reduce ph or TA?
    Not in any significant way. If you are concerned then just wait for the CYA to dissolve (about a week) and retest your pH and TA and make any adjustments you feel are needed.
